Plugged in my deck and the strobe light flashes and dims when playing the record when its still the light is fine i checked the r212 resistor and its perfect at 150.2 what could cause this?
SOURCE: Technics 1210 feedback problem hollow noise ??
More than likely it's your RCA cables, or it could be a tonearm or cartridge issue. First try and swap out the cartridges on your turntable, and see if the problem persist. If it does, then you can narrow it down tot the tonearm and RCA cables. Since the RCA cables are easier and cheaper to replace, I would suggest doing this first - You can try
to do this yourself, however soldering experience is required. You can
purchase the parts HERE - and install yourself, or try to find a reputable service center area to replace the cables.
A
word of advice, try not to use the original RCA cables that are
installed with the turntables, as they aren't of the greatest quality.
Try and put a better brand, or use the MOGAMI cables, available HERE.
If the problem persists, then the issue with your tonearm, and replacing the tonearm involves a lot more in-depth work, and I would only suggest having it done by a profession. You can buy the part HERE, and bring it with you to the service center, to minimize your cost.
There is nothing else that would cause this kind of problem except one of the 3 (or combination). So, by a process of elimination, you'll solve the problem.
Have fun!
- DJ PRO AUDIO
www.DJPROLAB.com
SOURCE: platter or motor or what?
Been seeing a lot of problems like this on the newer decks. if the lights instead of moving smoothly are moving a bit, then stopping a little, then moving a bit more. or just wobbling a little bit usually has something to do with the motors... I have also just had to have mine replaced to was having the same problem.... expensive
