Question about Motorola Mobility HS850 Consumer Headset
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
I have a bluetooth HS850 I can't get it to pair with my razr because i can't seem to get the signal light to stay on while i am opening the boom. I have tried the following: Close the boom hold the big button( talk button) the light comes on so i let go of the button and open the boom then after about 5secs the light goes off. Close the boom hold the button the light comes on while opening the boom i keep pressing the big button on top for five secs nothing happend ( i found this way on the web) Please help... (I have not go the headset to pair with the phone)
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Posted on Aug 16, 2007
NEED TO PAIR BLUETOOTH HS850 TO RAZOR V3
a With the headset’s boom closed, press and hold the Multifunction Button E until the headset indicator turns on (about 3seconds). The headset indicator turns on.
b Release the button, then open the headset boom. The headset indicator remains on.
2. Perform a device discovery from the phone. 3.select motorola hs850 and click pair 4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone. The device ID is now stored in the phone’s memory. Pairing is successful when the headset indicator flashes 10 times rapidly.
Feb 07, 2010 | Motorola Mobility RAZR V3
Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Jun 02, 2009 | Motorola Mobility HS850 Consumer Headset
How to connect motorola bluetooth hs850 to motorola V3 chandrabose
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 10, 2009 | Motorola Mobility S9 Headphones
Need to pair up my BLUETOOTH # N136 headset with my Razr V3 phone
if you need the code it should be 0000
could also be
6789
9876
4321
1234
9999
hope this helps
please rate well
Mar 06, 2009 | Motorola Mobility HS850 Consumer Headset
Can't pair HS850 Bluetooth I found with LG 9900 (Envy)?
It sounds like the found phone isn't locked and you can get into it.
In that case you haven't said that you've gone into Settings and switched its Bluetooth on, while your phone is Bluetooth pairing mode.
Dec 17, 2017 | LG enV VX9900 Cellular Phone
PAIRED MOTOROLA BLUETOOTH WITH SAMSUNG
hold down the connect button on the bluetooth tl the light stays on, then open the boom, release the button. The light should stay on now, and your phone should be able to find you bluetooth.
Jun 18, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
CANT CONNECT BLUETOOTH TO MY PHONE
  • Start w/ power off (Best way to make sure you are off is to plug the headset into the charger for 1 minute, then unplug & wait 10 seconds before continuing.)
  • Press & hold MFB. DO NOT RELEASE YET.
  • light will flash quickly a few times to indicate power on. (Still holding MFB)
  • After a few more seconds of holding the MFB the light should glow steady.
  • Once the light is on steady you may release the MFB and pair with your phone.
good luck
Jan 02, 2008 | Motorola Mobility RAZR V3
Pairing to bluetooth
The V3C cant pair with other phones.. I have to hold my bluetooth head set on top of my phone to get it to pair sometimes and make sure the headset is in pairing mode
Nov 09, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility HS850 Consumer Headset Logo
134 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
