Question about Sony Handycam DCR-TRV16E Mini DV Digital Camcorder
Sont DCR TRV16
Error code C:32:22 appears, tried changing tapes, and changiging power sources, error keeps appearing only funtions that works is tape eject. Rewind, forward and play do not work
  • Anonymous Jul 18, 2008
    Exactly the same descrived above..I cannot get out the tape..
Smack it!!
And have a look at www.camerahacker.com
Posted on Jun 08, 2008
SOURCE:
ERROR C:32:11
GO TO REPAIRING INTERNAL PROBLEM
Sep 09, 2009 | Sony Handycam DCR-TRV140E Digital...
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Sonytvr140 digital 8
Does the error appear when tape is inserted? Eject the mechadeck, take out the tape, try blowing hot air using hair blower for a short while, just to dry if there is any dew inside, if still the same, have the capstan motor replaced, thanks
Sep 11, 2007 | Sony Handycam DCR-TRV140 Digital Camcorder
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Aug 22, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony dcr-trv6 unable to load tape in deck
This is a common problem. The code indicates that the sensor for the supply reel has indicated lack of motion. If you have a cleaning tape, try it first because if the head drum hesitates, reel error codes often appear. If this doesn't help you are in for a service situation. There are other electronic failures that can cause false codes and operations in many cases. These usually involve cable connection failure. You still need a qualified servicer. Good luck, magic seadog
Aug 10, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Trouble using dcr-trv6 mini dv camcorder
This is a common failure in this model and unfortunately will not be resolved without a qualified servicer. The error code indicates a message for lack of reel motion. Most often it is an electronic connection problem and not an actual reel problem. Good luck, magic seadog
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Sony Handycam DCR-TRV16E Mini DV Digital Camcorder Logo
221 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
