Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washing machine
The agiatator in the washer seems to be locked up. It will go through all other cycles except the spin. I have fixed the safety switch last week and now this happened. I have it taken apart and can see a belt that does not appear to be on any pully of any kind. Could this be it? Just before it stopped spinning it shook violently.
CHECK THE LID SWITCH. IF IT BREAKS THE MACHINE WONT SPIN FOR SAFETY BECAUSE IT THINKS THE LID IS OPEN. HOPE THIS HELPS
Posted on Aug 24, 2007
Yes. Regards Advisor
Posted on Aug 22, 2007
Washing machine will not complete spin cycle, but does complete the agiatation cycles
Have you thought of replacing it with a new front loader?
They save tremendously in water usage. Mine sames me at least $40.00 a month.
Jun 21, 2017 | Whirlpool Washing Machines
The washing machine seems fine but will not start the spin cycle
Hello there, I got a whirlpool sport washer machine that is showing off code f-28 and it gets the door locked! I have unplugged it and have taken the toe kick plate to reach for the release lock. I select a cycle but it seems to send signals to the motor, inlet valves but it just stops and nothing happens,. so if you could help me I would really appreciate it! thanks joe
Sep 04, 2010 | Whirlpool Washing Machines
Washer will not agiatate, makes funny noise, will not spin
transmission sounds like its gone bad, will it spin, if it does it mite be ur timer
May 22, 2010 | Whirlpool Washing Machines
Washer will not drain.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Trying to locate the belt on a Whirlpool washer
Hi:
Your washer does not have a belt. It has a transmission, and they seem not to fail very often. Usually, the problem lies with the timer or some other switch. What exactly happens when your spin cycle comes around? Normally, after the wash cycle, the machine stops, then the spin cycle starts in the opposite rotation. The first thing that happens is the water is pumped out, then as the speed increases, the spinning throws the rest of the water out of your clothes. If your machine does pump down the water, but doesn't spin fast, then you might have a transmission problem, but if it also fails to pump out the water, you could have a timer or switch problem, as some machines won't spin with the lid open, and if the switch is broken, the machine thinks the lid is open.
Feb 15, 2010 | Whirlpool Washing Machines
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Knocking sound in agitator
    Your Agiator "Dogs" maybe stripped these hold the agiator in the wash cycle place you han on top of the agit. and try to turn it clockwise then go back counter colkwise is it feel like it is grabbing or just free spinning??
    Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer does not spin
    I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
    Dec 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washer will not restart.
    unplug it wait a few mins---- that should solve it sometimes these machines go in to a a "soft lock" condition
    Sep 30, 2007 | Whirlpool GHW9100L Front Load Washer
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    142 people viewed this question
    Sal De
    Marvin
    Marvin
    jimorris77
