Question about HP OfficeJet 4215 All-In-One InkJet Printer
How to fax
I have hp officejet 4215 all-in-one but i don't know if its connected to our house phone, how do i do that, need to fax. Thanks
  • 4 Answers
You would need to connect a phone line from the appropriate port on the all-in-one to an open phone jack in order to make faxing work. If that's a problem, you can use the scan feature and send docs by email as a workaround. If you want to get incoming fax service, though, you will need the phone line connected to the unit.
Posted on Aug 25, 2007
I can receive fax but cannot send fax on my HP 4215 xi
Check telephone out going, add std code, check FAX facility in your telephone connection
Aug 09, 2011 | HP OfficeJet 4215 All-In-One InkJet...
I have Vonage phone line. I cannot fax to anyone on my HP 4215 officejet. My officjet is connected to the wall jack and set to "slow" settings as advised in one of the HP solution forum. that did...
Press the setup button on teh front panel and go to fax set up
Under fax setup look for
ECM - Error correction mode
By default its ON turn it off and try to send the fax
But let me thing clear the telephone line which you have has definitely some disturbence
Apr 16, 2011 | HP OfficeJet 4215 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
How do I recieve faxes?
make sure you are plugged into an analog phone line (not a multiline phone). second I would put a phone on that line and have someone call it to see if it rings through. Let me know what happens
Jun 22, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 can not send fax
Check for dial tone at the fax machine
Plug in a telephone on the cable from the wall.
Do you get a dial tone?
Something is wrong with the fax machine.
Call the phone company or a telephone repairman.
May 27, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all in one
  1. Ensure that you have a two contact phone cable connected to line 1 socket of the printer and that the other end of the cable is connected to the phone jack in the wall.
  2. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 3 keys.
  3. Plug the power back into the printer, keep holding the # and 3 keys till you see “ Partial Reset ” displayed on the printer screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 08, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP officeJet 4215
Here is a link to the user guide.. This should provide info on how to program the fax to answer o n the second ring. I don't know however how you have 2 numbers assigned to one line?
Nov 03, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Hp 4215 all in one
may i know if you do have an answering machine that is connected on the line??is your line is just a regular phone line??
send me feedback for more troubleshooting instruction...
Sep 05, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
May 07, 2008 | HP Officejet 4215v All-in-One Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
59 people viewed this question
Ben Johnson
