Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Eek, i dropped my camera more times than i can count, and hanging around a bunch of rowdy skaters seemed to really do it in. we've dropped it so hard the screen cracked, but it was still working fine. after awhile the crack started collecting dust [ew]. and now this last time, the focusy thing was open when i dropped it and it now refuses to work. i've lost the box and recipt and everything, so i doubt if anyone would replace it, even if i did do the whole 'pay more than your camera's actually worth' thing. the light turns on like it normally would when turning it on, but nothing else happens. =[ any suggestions?
  • 73 Answers
Non - motorized lens cameras , will survive more drops ( ebay it - as is - for parts ) ;
Posted on Aug 14, 2007
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
How to put pictures from a computer onto poweshot a480 camera?
First of all, if you've edited the pictures in any way (opening a picture in a photo editing program and then saving it without making any changes counts as editing) then the camera most likely won't be able to display the images.
You can transfer files (not just pictures) to the memory card using a card reader. Plug the card into the reader and it will appear to your computer as another hard drive. Simply drag-n-drop files to it the same way you copy other files on your computer.
Jul 18, 2012 | Canon PowerShot A480 Digital Camera
Why isn't imesh counting my profile views?
I have had thesame problem, after a while it solved
Jun 08, 2012 | imesh.com
How to disassemble lens on a casio exilim ex-z75
Jim, I really wouldn't recommend this. It requires extreme patience and meticulous parts tracking. Note that junctions stated: "It's really hard to take apart,", and he ain't kidding.
Really recommend that you return to the remedies that you had been trying. Sometimes it requires many repeated tries to free the gunk from the shutter. I've found that for the smaller pocket cameras that the most effective solution seems to be extending the lens and tapping around the lens barrel with a pen/pencil. Then alternately opening the battery door with the camera turned on (no need to play with shutter modes). Then just alternate with tapping, battery door, tapping, battery door, and keep doing this until the shutter opens/closes. Once this happens, set the camera to continuous shutter mode and snap off about 100 pictures to final lubricate the shutter.Good Luck,t00nz aka CR
Nov 22, 2011 | Casio Exilim EX-Z750 Digital Camera
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
Flash doesn't work
don't drop a D80. wrap the fabric clipped onto the camera (say for hanging around your neck, which is a bad idea because of heat.) around your wrist two to three times, EVERY time you use it.
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Error code E:61:20 on Sony DSC-S600
This is the result of the gears in the viewfinder that run a barrel style gear are misaligned or mashing.
Two Solutions:
1. Replace or clean out and reseat the gears of the viewfinder. This requires a small bit of technical camera repair expertise.
2. Now do not laugh at this one. Turn the camera ON and immediately while the grinding is going on slap the camera very hard in the palm of your other hand. Do this repeatedly until the issue fixes itself. I have recommended and done this many many times and fixed a bunch of cameras this way. LOL The gears of the motor and the viewfinder barrel gear become misaligned so a good hard jolt seems to get them back in alignment and you should be good to go.
Good luck. Stop the laughing it works. LOL
Apr 06, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
59 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
