Question about Nintendo Wii Console
Remote malfunction I got a new wii console one week back. Was using it normally for one week. Suddenly no connection between the remotes and the screen. Tried changing batteries and re synchronising which are not working. It seems that no connection is established. The link is not appearing on the screen. Please help.
  • Nazeer Aug 17, 2007
    Solved the problem. Took out the sensor bar inverted it few times and there it goes!! I think there was some kind of loose connection within it. Now it works well. One more trick worth trying!!!!!
    Scholar:
  • 130 Answers
Do the LEDs light up when you press the buttons on the Wii Remote? Try simply turning off the console, and pressing the power button a couple times firmly on the Wii Remote. If it turns on the Wii, the connection should be established. If it doesn't turn on the Wii, some hardware is defective. Recommend calling Nintendo Support if this happens.
Posted on Aug 17, 2007
  • Ryan RIopel
    Ryan RIopel Aug 17, 2007
    If the cursor is not appearing on the screen, but the Wii Remote is connected, then the problem is with the Sensor Bar, which should be above or below the TV (remember to change the settings in the Wii when changing sensor bar location). The Wii Remote must be in sight of the sensor bar for the pointer to appear on the screen.
  • Ryan RIopel
    Great, Have fun! Please rate my solutions :)
What do u mean by invert the sensor bar????
Posted on Sep 03, 2007
GET A NEW WII
HAHAHAHAHAHAHAHAAHAHAH
HAHAHAHAAHAHAHAHAHAHAH
HAHAHAHAHAHAHAHAHAHAHA
AHAHAHAHAHAHAHAHAHAHAHA
Posted on Feb 01, 2008
SOURCE:
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
Wii remote wont connect ?
if it wont sync after using the red buttons then its just bad batteries from the sound of it or the remote has gone bad.
Try fresh batteries or let the rechargeables charge (assuming they arent bad)
Apr 30, 2010 | Nintendo Wii Console
How do i set up a second wii remote to my wii console
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Hope this helps!
Feb 02, 2010 | Nintendo Wii Console
Can't connect my Wii remote to the Wii
Take off the battery cover on the back of the wii remote and open the slot on the front of the wii where you put in the memory card:
http://g-ecx.images-amazon.com/images/G/01/ciu/09/d4/42196230a8a096736e5af010.L.jpg
Press the red button by where the batteries go in the remote and the red button by the memory card slot together and they should find each other and synchronise properly. If they ever lose synchronisation again just repeat the process.
Dec 30, 2009 | Nintendo Wii Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
Sep 22, 2009 | Nintendo Wii Console
Controller problem
This normally happens when the battery,s in your Wii remote are low. Try a new (fresh) set of battery's. The alkaline type works best!!
Dec 28, 2008 | Nintendo Wii Console
Wii controller cant connect to wii
is your wii remote sinced recently???
Dec 25, 2008 | Nintendo Wii Console
Wii sensor bar
possibly, or low batteries in the remote. Try placing the bar under the tv if its above at the moment, or vice versa if currently below. Also make sure sensor bar overhangs tv slightly too...
Mar 08, 2008 | Nintendo Wii Console
2nd wii remote will not connect with mario play 8
We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
This is from www.nintendo.com/wii :
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Dec 23, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
269 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
