Question about Tannoy Mercury MX4-M Main / Stereo Speaker
Humming Sound I'm facing difficulty with one (left) of my Tannoy mx4 speaker. The lower most driver (bass) is giving out cracking/humming sound. It is very apparent when you increase the volume. I'm using Marantz amplifier. I tried switching the Left and Right speaker connection to the amplifier to isolate the problem and make sure it is not related with the amplifier. The sound came from the same speaker irrespective whether it was connected to the left or right terminals of the amplifier. Physical inspection shows that the driver is fine and nothing wrong with it. Can you suggest what should I check and how to solve this issue?
    Problem Solver:
  • 4 Answers
1. Check the cable of speaker which gives out the hum/cracking sound.Interchange the cables with the one that is working okay and find out if the hum still persists on the relevant Speaker. If the hum has gone, then replace cables ( to be on the safe side replace both right and left channel) to the speaker.If the Hum still persists, check the input female plug of the defective speaker and check if it is not lose or the solder has not gone wet. If so resolder both the wires of the connector by removing it with a soldering iron and scrapping the points of solder with a blade. If the problem still persists. Open both the cabinets. Mark the defective driver with a marker pen. Remove the non problemative driver and replace in it's place the Humming driver and check the configuration on both channels. If there is is problem then it has to do with driver and has to be recoiled and reconed ( ofcourse with a little quality lost) which could be done by any Speaker repair shop as per the manufacturers specifications. If the speaker works fine then the problem has to be either of the crossover network or tweeter. So remove the cross-over network from the defective speaker setup after marking it again for identification, and replace it in the good working speaker, where you now connected the humming speaker. If there is a hum, then the problem is the cross-over network, which should be replaced. If the hum is not there, again try similarly with the tweeter and I am sure you will get the Hum, and you may get a new one of similar specification from the market or get it repaired by a speaker shop. Replace the original configurations as was before. Woofer to its original places and similarly cross-over and tweeter ( as was before you opened the cabinets). Now you have identified the problem, solve the problem by repairing or replacing the culprit device. I am sure you may not have to go to all these. Perhaps it might be a loose connection or cable problem or even earthing problem. If you do not want to go through all these. Show it to a specialist with reputation ot take it to the company's service centres whose address in your area or nearby area you could get from their official site. Please note I have given my guidance on the premise that the amplifier if fine and has no problem.
Posted on Aug 22, 2007
Wiring power house phd2 mono amp to the earthquake 4 ohm speakers.
When i hooked up my bass knob the amp made my subs hum i unhook the rca but still humming unhook bass knob still hummin
Jun 12, 2011 | Earthquake Sound PH-D2 Car Audio Amplifier
Tip
Biwiring
use biwiring --- improves the sound quality a lot..esp the bass effect
on Aug 14, 2007 | Tannoy Mercury MX4-M Main / Stereo Speaker
Humming sound from left spesker
sounds like the cartridge lead on the left side of your cartridge is coming off. Or the ground cable of your tone arm or your table is loose.
Jul 19, 2010 | Gem Sound BJL-1150 Turntable
I have a creative2.1 desktop speakers. now i produce a humming sound when i switch on the speakers
Try reducing the Bass of the woofer. Also try moving it away from any other electrical devices as there might be interferance from other devices resulting in the humming sound.
Please rate if helpful.
Thanks
Apr 12, 2010 | Audio Players & Recorders
Scratchy sound from one hifi speaker
Determine if the noise is only from one driver. If it is gently press all over with your fingers on the cone, so it moves up and down. If it makes the noise then then the cone is catching inside the housing. You will need a new unit if that is the case.
Before you do any of the above swap the speaker with another so you know it's not the amp causing the noise.
If the whole speaker makes the noise and it's not the amp, then it will be a fault on the crossover inside the speaker.
Feb 10, 2010 | Tannoy Mercury MX4-M Main / Stereo Speaker
Humming sound to speakers from amplifier
It sounds like you may have a ground loop issue. I'd start by checking all the power and ground connections. Then disconnect the RCA wires from the amplifier. If the hum goes away then you should try grounding the stereo to a better grounding point, the factory grounds are usually not very good at all. Then try it again, if it is still there try replacing the RCA"s.
If the hum is still there after you've redone the connections and replaced the RCA's, you may need to install a ground loop isolator.
Both www.crutchfield.com and www.sonicelectronix.com sell good ones.
Hope this helps
Mar 28, 2009 | MTX X Thunder 1000XD Car Amp
Subwoofer amplifier hum on high bass boost.
Try attaching a crossover caps of 0.22mf over the inline resistor(out put). This will filter the humming sound created when no sound is played.
Roshan.
May 23, 2008 | Audio Players & Recorders
No signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Jan 24, 2008 | Onkyo TX-SR703 Receiver
X-230 Speakers Hum
bad brain in it or u can try to see if its pused in all way cables in back dl latest sound card drivers
Jan 16, 2008 | Logitech X-230 Computer Speakers
Tannoy Mercury MX4-M Main / Stereo Speaker Logo
634 people viewed this question
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
Rommel Balcita
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
