Sharp LC52D65U 52 in. LCD TV Logo
Posted on Mar 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The tv quit responding to the remote
I cannot turn the tv on or off with the remote. if i unplug and re-plug the
power cord then i can use the remote for 1 or 2 days..then it quits again.
the tv turns on ok if i do it manually
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Mar 19, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
22248
Points
158
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
TV WILL NOT TURN ON
      NOTE: If the TV turns on and off using the POWER button on the TVbut does not respond to the POWER button on the remote control, troubleshoot the remote control. Unplug the TV power cord from the electrical outlet for 30 seconds. Plug the power cord into a known working electrical wall outlet.Aug 15, 2015
      The TV will not turn on or does not have any power. - SONY
      https://us.en.kb.sony.com/.../the-tv-will-not-turn-on-or-does-not-have-any-...
    Feedback
    TV Will Not Turn On - Troubleshooting Help for Finding ...
    ? 2:32
    https://www.youtube.com/watch?v=kEDVc-BXf0I
    May 1, 2014 - Uploaded by ShopJimmy.com
    TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and causes of ...
2answers
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
High school musical tv
Resetting the TV
NOTE:
1. Unplug the TV power cord from the power outlet for 4 hours.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Helpme please
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
1helpful
Tv is on but wont play
Resetting the TV
NOTE:
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Samsung 40" Full HD LCD
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
3helpful
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Picture gets hung
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
2helpful
Samsung lcd tv
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
