Question about HP vs15 15"LCD Flat Panel Monitor
HP 15 in. Flat panel Problem
The screen is black with the power button on. If I turn the monitor power button off, then on again, I will get a picture for about 5 seconds before it goes black again. I have also tried rebotting the computer and I momentarily get a picture before it goes black again. Any ideas or comments would be greatly appreciated. Thanks. Rory
  • Anonymous Dec 04, 2007
    My friend is having this same problem. Before I travel to her house to try to fix it. Did this work for you or are there any other suggestions?
  • 56 Answers
Plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Posted on Aug 15, 2007
My home dell computer monitor has went black with a box on it. * The floating dialog box appeared on screen (against a black background) * The dialog box float around the screen without any visual...
The dialog box you are seeing means that the monitor is not receiving a signal from the computer.
check your cable going from the monitor to the computer. if the cable seems ok, hold the power button on your towerr until it turns off, then wait 5 seconds and push the computer power button again.
Cheers
Dec 26, 2017 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor keeps turning on and off? it wont even show the screen for more than a second or two and then switch to black again.
your LCD inverter is almost dead. the monitor itself actually remains on, but just goes to black each time the LCD inverter cuts out, since this is what supplies white light to the screen.
In case you wanted The FP5315 Users Guide, or 3 other HP documents for the HP FP5315 LCD Flat Panel Monitor:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=324205&
Jan 05, 2011 | HP Compaq FP5315 15" LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
15" HP Pav. monitor turns on for a second but immed blacks out
Pls ask your dealer about the warranty..It depends as per the market.. If the light is comming then replace the AD card other wise The problem with the inverter card.. replace ...
Jul 06, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Black screen
Hi
my problem was fixed by viziks from FixYa dated Sep 12
replaced 2 push pull transistors 2sc5707 in high voltage transformer circuit
Transformer used for backlight lamps
Both monitors now working THANKS VIZIKS
Feb 09, 2008 | HP vs15 15"LCD Flat Panel Monitor
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
243 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
