Question about Mitsubishi WS-55819 55" Rear Projection Television
The best ways to move my 55 inch Mitsubishi TV to another home?
The only time this tv was moved was from Circutcity to it's present spot. Now we bought a new home and I want to move it without messing it up. HELP !!!! Alph of Spokane WA
    President:
  • 3,130 Answers
Move it with an appliance hand truck and do not lay it on it's side. When transporting, always keep unit standing upright. Good Luck
Posted on Aug 14, 2007
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Help
Soulds like a cold solder joint that was disrupted during the move..or a cracked board..or a dislodged connecter. Unplug, remove pack. Take ntes..remove chassis boards...clean with compressed air. Chk for cold solder spots..heat stress. Repair. Reinstall board..noting where all connectors go. Good luk. Anything more..could need servicing..burnt out capacitor,,etc.
Trace Electronics, Barrie, ON
May 29, 2010 | Mitsubishi WS-55511 55" Rear Projection...
After a move to a new home the screen broke. need
Howdy,
Yes, you can still get them from the Factory. I just checked and Mit's has all items in stock.
The SCREEN- LENTICULAR IS; 491P103030: $171.10. The LENS-FRENSEL IS; 491P104030: $212.80. The Diamond Shield IS; 760D639020: $77.90.
Dec 29, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Nov 17, 2009 | Televison & Video
Out of focus
You have a convergence problem, probably the convergence electronics are going out or the TV has been violently moved and needs a mechanical alighnment. Small adjustments can be made from the menu.
May 17, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Purple blotches on Mitsubishi WD 52527
yes you can clean it. i clean mine all the time. after you remove the screws at the bottom you should be able to just lift it up. it will be hard be cause there is sticky tape with a hinge that the hole screen sould just lift off. i know it doesnt feel like it but it will. just do one side at a time. now the problem with the purple spots are because you move a speaker to close to the front of the tv the was not shielded and cause it to do this. you can move the tv so that the earths magnetic field will restore it for you. make sure the tv is not plugged in when you move it for 2 to 3 days . after the 2 to 3 days plug tv back in and leave on for 2 hours. after this you can move it back and plug back in. this should fix it. if not you will need it to be degoudged. tv repair center can do this at your home. hope this help you.... thanks eddy
Jan 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55809 55 inCH tv
best way i would trouble shoot this would be to get a can of freeze from radio shack and spay the tuner if the problem comes back you know it's the tuner if not spray IC one at a time till the problem happens.
Dec 11, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Taking apart and moving a 55 inch projection TV
hi do this as last option! there is 30,000v inside the tv!! you can die before you even think about it the only way to do soo is unplug the T.V from the wall for a week at least (so the volt will dissolves) you can turn the tv on its side you will have a problem if it will get a slap or will fall in my opinion just take on its side....but its your decision JUST BE CAREFUL PLEASE!!! good luck
Mar 20, 2006 | Pioneer SD-P55A3-K 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
367 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
