Question about Panasonic Panafax DX-800 Plain Paper Laser Fax
Panasonic dx-800 fax machine
I am trying to change the access code for our fax machine. I am following the directions in the manual on page 168 and it is not working...Any suggustions? I have also tried to erase the access code as per the instructions but to no avail.
    Problem Solver:
  • 5 Answers
Simply remove the battery and let the machine set for 2 days. This will erase all data. Or you can do a shipment set, which sets the machine back to factory defaults.
function then 7
Monitor four times then press the * key
press 6
up arrow until you see Ram Initalized
press Start
wait for it to complete, it will restart its self
press Stop twice to get out.
Posted on Sep 11, 2008
    Sergeant:
  • 284 Answers
Dont need to remove the board if you leave me an email i will tell you how to bypass the code inside to reset it or see it
    Scholar:
  • 130 Answers
I am a technician. If I was asked to resolve this problem I would; remove to main board from the machine.The main board usually holds information that is stored in the fax machine, such as date time phone numbers access codes etc. Examine the board for damage to components. if a battery is present remove it, if possible. Let the board sit , over night if possible. Using a small screw driver, short all viible capasitors, they hold charges. Then replace in machine. prior to doing this take all electrical/ ESD precautions. If your codes are not gone then you may have bad circuitry. Replace the board ,if possible, with a new or used board.
Posted on Jun 16, 2008
SOURCE:
Dx-800 wont work with answering machine. Tried all the fax settings to use with a tam. Tam picks up line then dx-800 drops out everytime.
Set the answering machine to answer on 4 rings and the fax to answer on 6 rings.Do this with answering machine menu.
May 15, 2011 | Panasonic Panafax DX-800 Plain Paper Laser...
Our dx-800 reads OUT OF TONER INFO CODE = 041. We have replaced the toner several times. This was intermitant over the last month. We would unplug and repower and it would go away for a while.
Toner sensor holder kit (The silver part in center, directly below the toner) needs to be replaced by an authorized Panasonic repair center. Call Panasonic for one in your area.
The part should cost no more than $30-50. takes 5-10 minutes to replace. Most service places charge minimum 1 hour fee and possibly travel fees. so you are looking at $125-250 repair bill.
If the unit is out of warranty, Panasonic won't do it for free.
I have replaced the sensor kits on numerous DX-800 and it basically avoids displaying the toner errors, and you replace when print becomes light...the good old fashioned way.
Panasonic Support: 800-211-7262
Jan 26, 2010 | Panasonic Panafax DX-800 Plain Paper Laser...
DX-800 beeps with Incomplete Info Code = 720
Error Code 720: Cannot connect to the Pop Server. (Incorrect Pop Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the network Administrator
Regarding the beeping noises. The DX-800 has multiple settings for beeps, rings and the dialing monitor. If it is the latter, press MONITOR button once, then press the DOWN arrow, until silenced. Some ringer/beep settings are under Fax Parameters, some are in a special SERVICE MODE.
let us know if you can isolate which one and we can help turn it off. At least now you know what the 720 code means.
Good Luck!
Nov 10, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Have a gibberish incoming fax that won't stop. how do we clear the incoming memory on a DX-800
press
function
7
monitor slowly 4 times
6
scroll down to ALL JOB CLEAR
wait for reboot
Jul 16, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Keeps printing pg 1... sender's machine says it isn't going thru
Press
Function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for the machine to reboot
Jan 13, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Email address
Press function 62 and print out the one touch list and make sure the address is typed correctly.
Sep 09, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Panafax dx-800
Press Function, then 7
Press 4, then Copy/Set
(it should ask for a fax parameter, the one for the key sound is 010)
Enter "010", then Copy/Set
Set the parameter to "1" for Off, then press Copy/Set
Press Stop to exit back to the default screen
Jul 23, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Panasonic Panafax DX-800 Plain Paper Laser Fax Logo
352 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
