Vehicle Parts & Accessories Logo
Anonymous Posted on May 20, 2013
How to find an audio jammer that is located on my property but I don't know where.
I need to prove there is an audio jammer being used on my property, my bf says I'm crazy and is making me believe it. I need to know how to prove either he is using one and denying it or that one of the neighbors is. HELP
bjg8
Level 2:
Sergeant:
  • Expert 174 Answers
  • Posted on Oct 22, 2013
bjg8
Expert
Level 2:
Sergeant:
Answers
174
Questions
Helped
35718
Points
511
Call a friend from where it can here u.Start walking till it cant here u no more,Step back untill it can here u again .Repeat from other position till u get a circle.In the middle u should have your jammer depending of the buildings/geografy and other obstacles.
How does a mobile network jammer work
A mobile phone jammer is an instrument used to prevent cellular phones from receiving signals from base stations. When used, the jammer effectively disables cellular phones. These devices can be used in practically any location, but are found primarily in places where a phone call would be particularly disruptive because silence is expected. A cell phone signal jammer is used to stop nearby cell phones from sending or receiving signals to and from the cell phone tower. A cell phone works by communicating with its service network through a cell tower or base station. Cell towers divide a city into small areas, or cells. As a cell-phone user drives down the street, the signal is handed from tower to tower.
Cell phone jammers block cell phone use by sending out radio waves along the same frequencies that cellular phones use. This causes enough interference with the communication between cell phones and towers to render the phones unusable. On most retail phones, the network would simply appear out of range. Most cell phones use different bands to send and receive communications from towers. Jammers can work by either disrupting phone to tower frequencies or tower to phone frequencies or both.
Cell phones are full-duplex devices, which means they use two separate frequencies, one for talking and one for listening simultaneously. Some jammers block only one of the frequencies used by cell phones, which has the effect of blocking both. The phone is tricked into thinking there is no service because it can receive only one of the frequencies. The jammer also stops Internet use through Wi-Fi network and even blocks Bluetooth connections. The cell phone signal jammer also puts an end to text messaging, so students cannot SMS each other, while the teacher is trying to teach.
Interestingly, jammers are life saving devices for military. Terrorists use cell phones to trigger explosives. Army can use a jammer to make mobile phones go dead, so that army technicians can deactivate the bomb.
Jan 28, 2013 • Cell Phones
1helpful
2answers
Why is that my microphone not working?
First thing to know is, did music play normal? In other words, can you use a computer to listen to the song?
I don't know what you mean is a chat does not work or a sound recording does not work, follow the following steps to try:
1, your microphone in the figure below, there is a high, click on it, there should be two check boxes, how did you uncheck? If you don't check at all, please don't pipe it. <B> above and to the left in the figure
2, you click 'options'-'Properties' in the open 'Properties' dialog box, choose 'single recorded' radio button selected in the box below 'microphone' and then click OK. Recording Control Panel appears (you playback control panel shown in the figure), the interface that appears with your diagram is essentially similar, but note that the mute here becomes a choice, you try to choose a microphone and volume to its maximum, and then see what effect? Similarly the microphone below also has a high, do the first step the same thing and then try.
If you have done the steps above does not help, try this:
right-click the computer speakers at the bottom right of the screen, select 'adjust audio properties' in the open 'sounds and audio devices properties' dialogue box, select the 'voice' tab. Click on the bottom 'test hardware', and then follow the prompts, if passed, it means that your hardware no problem, and the driver was installed. If the tests pass in place, keep an eye on it and then follow the instructions it make any adjustments.
If it is a driver not installed, reinstall it again. If you do not install, I am sorry, it is difficult to express in words clearly, please look for people to help one understand the installation. You can right-click on 'my computer' select 'Properties', and then open the 'hardware' tab, then click on 'Device Manager' in the Device Manager, there should be no yellow or Red Cross or an exclamation point appears, if you have to prove that you a device that is not working properly, of course, does not rule out is your sound card.
2helpful
I need to download three drivers from dell for a optiplex 755 with windows Vista business operating system
hi,
below is a link to try if you haven't already, you will need to know if you are 32 or 64 bit. however if you select wrong it will just not work. then try the other. but this should have what you need
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PLX_PNT_P4_755&os=WLH&osl=en&catid=&impid=
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
2answers
I need to sound card driver
Hi, you can download the driver here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5VD2MX/#download
Select first your operating system 32 or 64 bit.
Then select audio and click on global for download.
The file needs to be unziped before installation.
When unziped choose the installation program or exe file.
You may need to restart after this.
Here is a free unzip program:
http://www.7-zip.org/download.html
Just click on the exe file for download.
Hope this will help you.
1helpful
IP Address Conflict... So I have two computers at home. Two Dell Desktop computers running Windows XP. Both have USB wireless network adapters. I don't own internet (Don't shun me. My fam...
although I don't support IP Pirates(if they can afford not to be). there is one trick that may help but not if the security on the router is strong as they can set it to only hand out 1 number. However if you know the IP(192.168.0.2) that is being handed out. then you can manually set the wireless adapter on the second system to have an IP that is +1(192.168.0.3) (instead of a DHCP setting)of the number you are given. make sure the gateway and subnet mask is exactly as is handed out to the first system.
you can easily view this info. from a command prompt and typing:ipconfig /all
GL
hope this helps
Thank You
Jammer
What does the blinking orange light mean on my dell CPU, I can't get it to power up
dell only knows 2 colors blue and orange... if you have no light on the mother board when power is plugged in. then your power supply is probably gone. considering you didn't mention beeps I would say thats it.
GL
hope this helps
Thank You
Jammer
I recently purchased a new computer (HP/Windows 7) and am having difficulty loading my copy of PDFCreate!3. The error message is: "AddPrintDriver Cause of Failure - 2". Is this version of...
hi,
it does appear that even create 4 didn't have windows 7 support. You may try installing and then changing to windowsxp compatible mode by right clicking the icon and selecting properties and the compatibility tab then place a check in "run this program in compatibility mode" and choose windopws xp. and or install virtual PC with windowsxp compatible then install and run your older software in a virtual machine.
GL
hope this helps
Thank You
Jammer
My 2nd pc needed to be formatted & system reinstall & now there are drivers missing & not being able to connect to the internet i cannot install ie:- ethernet controler,vga,audio,sms, usb,...
that would be the fastest way as it would have the base files need to connect. of course all you really need to get started is the network card. you can download (http://www.msi.com/product/mb/) the network files and put them on a cd/floppy/flashdrive. and go to device manager and attempt to update the ethernet. from the file location(wherever you saved the files too).
GL
hope this helps
Thank You
Jammer
I see the letters backwards in my Sony XGA VPL-CX10 projector. how can i fixed?
there is an image flip setting that I hope you are refering to when you say "backwards".
each unit is diffrent and I couldn't locate that models manual. however in the function menu you should find an image flip setting. as it is with most of their models
hope this helps
GL
don't forget to vote for me
Jammer
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
