ok but what if you dont have the original remote that came with DVD Player....then what????
Same Problem
Apr 20, 2009
-   player says its loading but after a few minutes says no disk-   Guest
Dec 07, 2008
-   i dont have the original remote.. what can i do for the wrong disk displayed??? -   Guest
Sep 02, 2008
-   yes i have the same probleme but what is it strange the disk just won't spin an it say no disk.is it possible the pick up lens is finish and i ear a click wen the tray close an the dvd charge i ear a clik,and do not spin.help please.-   Guest
Dec 02, 2007
-   My Dvd is not saying "wrong Disk" it is saying "no Disk", It was working find and then suddenly when we went to watch rented DVD number two it won't read that a disk is there....-   mitchella
Nov 25, 2007
-   I have the same problem...would really like to use this DVD player...what is the solution and how will you let me know?
sellacott@hotmail.com-   Guest
Best Solution
posted on Sep 25, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
try to find crack for region code and set it up to be region free. that should do the trick.
try this - hopefully it helps. Wait for the "wrong disk" or "no disk" message appears. Press Open/Close. Press set up on the remote. Enter "1389" in the menu then enter "0" for regionless in the region menu. Press "Enter" then "Setup" to exit.
Guys, it is working but with a little correction in the setup process. You have to follow all instructions mentioned above except this one - as you put all numbers "1389" don't press "0" key, but change the currently appeard region number on your screen by pressing arrow UP or DOWN keys to get "zero" on the screen. After this follow the above instr. to complete the setup.
diamond vision dvdv804-03a. Somehow have got video switched off of s-video so can't see setup menus....
(More)
diamond vision dvdv804-03a. Somehow have got video switched off of s-video so can't see setup menus. Any way to reset it back to s-video ? tia
I have a problem with the Diamond Vision DVDV804-04 that it isn't able to read disc. Waht can I...
(More)
I have a problem with the Diamond Vision DVDV804-04 that it isn't able to read disc. Waht can I do?Thanks
