Question about Canon PowerShot A430 Digital Camera
Lens error Hit there my lens is all the way out and stuck there. When I trun It on it say lens error, restart camera. Than the camera shuts down on its own. I put new batterys in it still nothing.
  • 1 more comment
  • Anonymous Jan 28, 2008
    Hello Justin,
    Thank you so much for you tips. It really worked and I can use my camera! I was about to buy another camera since repair costs almost like a new one. Thanks a lot...............Shlomo
  • kb-sc Feb 21, 2008
    my leans was out and i droped it on my bedroom floor and now it wont come on well it comes on but it tells me 2 restart the camera and i just got it this X-mas and i dont think i can take it back what do i do ,,, and i have a power shot A430
  • alex-mylo Mar 13, 2008
    same thing it is stuck out wont come back in " lens error restart camera" how do i restart?
Hello Justin,
Thank you so much for you tips regarding lens error. It really worked and I can use my camera! I was about to buy another camera since repair costs almost like a new one. Thanks a lot...............Shlomo
Posted on Jan 28, 2008
  • Canon Master
  • 4,738 Answers
If the A430 camera is no longer under warranty, here's how to fix it, and it's relatively easy: http://homepage.mac.com/jpelling/page0/page0.html By the way, don't know Justin, but he did a very nice job showing how to open the case and clean out grit and sand from the camera's drive gear. Make sure you send him an email to thank him :)
Posted on Sep 04, 2007
  • 641 Answers
It seems as a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
SOURCE:
The lens is stuck open and when I turn the camera on it says lens error will shut down automaticlly restart camera
Try moving around the lens GENTLY. If does not help, call Canon, they will probably fix or replace it.
Aug 29, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I have a canon camera IXUS 105 and the lense is stuck out and when i turn the camera on it says 'lens error, will shut down automaticly, restart camera' i have restarted it many times but the lenses wont...
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 05, 2011 | Canon Cameras
How do i restart my cannon ps sd;1000.. the lens is stuck open and i can't shut restart it
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Apr 24, 2010 | Canon PowerShot SD1000 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
WE WENT TO THA BEACH AND TOOK SOME PIC AND LATER THAT DAY WHEN WE WENT TO TAKE MORE PIC IT SAID LENS ERROR RESTART CAMERA BUT WE DON'T KNOW HOW TO RESTART THE CAM
Aug 18, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera turns on BUT then get "lens error restart camera" msg
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2008 | Canon PowerShot S3 IS Digital Camera
Lens error on brand new G9
i got the exactly same problem!!
i bought it on 16th/Feb, next day,17/Feb not more than 20 pictures i took, the issue comes (lens won't action while shift the zoom lever, but it's working ok while switch on and off the camera)
so i bing it to the shop with my angry, they just said to me that you must dropped the camera.
--but i sware i didn't !!!
now they took the camera to Canon base for the exam...
Jan 20, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lens will not close
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 11, 2007 | Canon PowerShot SD850 IS Digital Camera
Canon PowerShot A430 Digital Camera Logo
112 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
