Question about Sharp UX-B800H Fax
Fax to Email
I can no longer get my Fax to do fax to email.
3 Suggested Answers
  • 1113 Answers
SOURCE: Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
1 Press FUNCTION once and 3 times.
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
Using TEL Mode
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Posted on Oct 17, 2007
  • 66 Answers
SOURCE: Error 4103
A loop current problem indicates that the phone line is not connected to your fax correctly, the cord is broken or where you have plugged into the wall is dead
Posted on Jun 22, 2009
  • 811 Answers
SOURCE: the print on receiving fax are too small . how can
Yes you can do this in the review print click and modify the text size using the word program until you get the right size. You can see it in the print preview section before you click print. John
Posted on Feb 04, 2011
0 characters
1 Points
Can't send and receive a email
You have to fax email copy it then fax. and the same the other way print it to paper and send it. It's a fax machineIf you have 4 in one then you can have a email address just for your machine
Mar 11, 2014 | Panasonic KX-FB421 Plain Paper Film Fax
Scan driver
What problems do you have with your scan driver????
If you need to scan a document, and you have problems with your scanner, you can use the Popfax service:
1. Subscribe for Popfax fax email paid or free offer
2. Send the document you wanted to scan by fax, from your fax machine to the Popfax fax number
3. ou will receive the document in PDF on your email .
Easy and cheap! Try it now!
Jul 11, 2011 | Fax Machines
Code 721 keep coming up and the machine keeps beeping. How do we fix it?
Error 721: Cannot connect to the Pop Server. (Incorrect POP Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the Network Administrator
Were you setting up email by chance, you need to make sure the email server settings are set correctly for your POP email provider. Otherwise you will get this message. If you don't use email, go into settings (Fax Parameters) and disable email features.
Apr 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
I just switched my internet Server from Comcast to Verizon.I was told that the dedicated line I was using for my fax would also service the new Verizon Server. The fax( 2820) recieves incoming fax's but...
Finally, I have the email that works with B800SE BROADBAND FAX. If you would like an email to test, please send me an email. One email is $12 only for one year.
Feb 23, 2009 | Brother Fax Machines
I bought Nakajima Ax-530 typewriter.Need user manual.Where can I get it?Please help.
Ntry here!orth American Distribution
425 East Arrowhtttttffead Drive
Charlotte, NC 2
North American Distribution
425 East Arrowhead Drive
Charlotte, NC 28213 North American Distribution
Charlotte, NC 28213
Phone: (800) 809-7138
Fax: (800) 809-7153
Fax: (800) 809-7153
Fax: (800) 809-7153
Oct 15, 2008 | Fax Machines
Verify that that the email address is valid by sending an email to them from a computer.
Sep 09, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Email address
Press function 62 and print out the one touch list and make sure the address is typed correctly.
Sharp UX-B800H Fax Logo
Top Sharp Fax Machines Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Fax Machine Expert? Answer questions, earn points and help others
