Question about Kenmore 22442 Top Load Washer
Washer not spining
Took apart see alot of oil dripping and exteremly loose belt
Blown motor capacitor.
Posted on Aug 31, 2007
  • 641 Answers
Replace the loose belt. Regarding the dripping oil,look for the defective shock absorber. Good luck!
Posted on Aug 30, 2007
Kenmore Series 80 Washer Drips and Spin Cycle Sometimes Has Low Torque
Does it leak every time it's run, or only occasionally? It could be that the belt on the drain pump is going bad or is loose, so it works some times but not always. Could be that the belt broke or the drain failed, so it will always leak from now on. It's hard to say without actually taking it apart and having a look
Dec 31, 2012 | Kenmore Washing Machines
My lg washer shake s alot when it is spining and makes a loud noise please can you help
The washer needs to sit on a solid foundation for this to work. When the washer is spinning a load of clothes, push the corner of the washer till the noise or vibration quiets down. When it does quiet down, adjust the leg below to reduce the noise.
Good luck
May 26, 2011 | LG WM-2277HW Front Load Washer
When washer is spining it makes alot of niose...is it the belt..
This machine doesn't have a belt. Instead it uses a motor coupling. A very common problem, that occurs when one overload it.
Washer repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Jan 26, 2011 | Roper RAS8445KQ Top Load Washer
12 year old kenmore elite topload washer - replaced the coupler - works fine except makes horrible noise in any spining cycle- seems to be a rubber belt or gasket around the tub drive area but can't see...
ok lets see if i can help you out,, first the model number ( on most models) is on the inside of the lid, or raise the lid and look on the rim of the washer under the lid,, if its not there it may be on the back of the unit,, or in some cases its gone, fell off , wore out, ect.. second,, if the motor coupler went out then it may be a issue with your trans,, ive seen alot of these where the trans starts to lock up, or the bearings on your shaft start to seize, break the coupler
Jan 19, 2011 | Kenmore Washing Machines
Amana LW8303L2 will not spine
http://www.washerhelp.co.uk/washing-machine-repairs.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Belt replacement on these is a slightly intimidating job to the uninitiated, but possible.
http://www.american-appliance.com/se...stic-Chart.htm
http://www.applianceaid.com/amana-wash.html#belt
Lots of pictures and help at these sites.
Main thing is use ONLY the factory-authorised replacement belt on these. It is designed to have the right amount of slip/grip to enable your washer to work properly. This is CRITICAL on Amanas.
Apr 14, 2010 | Washing Machines
Washer not spining burn smell
belt burrt out advise new belt or new machine
Jul 12, 2009 | Maytag LAT3600A Top Load Washer
MAV7700
I changed the drive belt, so far so good. The belt I took off really didn't show signs of being bad, it may have been slightly glazed. Also, the drive motor is set to slide back and forth, I lubbed the glides. 3 loads have been run and it appears to be fixed.
Mar 30, 2009 | Maytag MAV7700 Top Load Washer
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer not spining
i think there is problem in your water outlet pump problem first of all you check water is come out or not from machine
Feb 11, 2008 | GE Profile Prodigy WPSE4200A
Kenmore 22442 Top Load Washer Logo
110 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
