Question about Microsoft Office Standard for PC
How to activate command buttons
Hello, I added 5 different command buttons to my form with the wizard. I followed all the steps (ie. gave the buttons names and commands such as print record, add record, delete record and so on). However only 2 out of the 5 function properly and carry out the commands (delete and print commands). When I click on the others, a dialogue box pops up and says " You can't go to the specified record" I'm not sure why the others are not working. Can you let me know how I can get the add record command to work? Many Thanks! signed Access beginner
  • jiggadel Dec 04, 2008
    i am not seeing any instructions to follow when i insert an action button in ms access 2007
    Problem Solver:
  • 9 Answers
Not w/o you sharing how you did it step by step. Can you add some screenshots of the steps you tok to get there? In general "add record" should jump to another form that allows you to enter your data for the new record and "save" it.
Posted on Aug 15, 2007
  • Anonymous Aug 15, 2007
    Found this expertly mention of the type of error you are getting on MS-Access website.
    SYMPTOMS
    Advanced: Requires expert coding, interoperability, and multiuser skills.
    When you perform an action in the BeforeUpdate event, you receive the following error messages, even if you have canceled the event.
    In Microsoft Access 7.0 and 97:
    - Runtime error '2105'
    - Runtime error '2115'
    The macro or function set to the BeforeUpdate or ValidationRule property for this field is preventing Microsoft Access from saving the data in the field.
    In Microsoft Access 2.0:
    - Field or record can't be saved while it's being validated.
    - Command not available: UndoCurrentRecord.
    - Can't go to specified record.
    CAUSE
    Microsoft Access cannot perform the specified command because the BeforeUpdate event procedure is still running. This is true even if the Cancel parameter is set to True or if a CancelEvent macro attempts to cancel the action.
    These error messages are generated by the following statements in the BeforeUpdate event procedure:
    ' Undo the current record. (Microsoft Access 2.0 only)
    ' NOTE: This behavior no longer occurs in Microsoft Access 7.0 and 97)
    DoCmd DoMenuItem A_FORMBAR, A_EDITMENU, 1
    ' Goto a new record.
    DoCmd.GoToRecord , , acNewRec '(Microsoft Access 7.0 and 97)
    DoCmd GoToRecord , , A_NEWREC '(Microsoft Access 2.0 )
    ' Find a record
    DoCmd.FindRecord "Smith", , True, acAll, True '(Microsoft Access 7.0 and 97)
    DoCmd FindRecord "Smith", , True, A_ALL, True '(Microsoft Access 2.0)
    RESOLUTION
    Instead of setting the Cancel parameter to True, or using the CancelEvent action, use a SendKeys statement if that is an option with the command you are trying to use. The SendKeys statement sends keystrokes to the Microsoft Access buffer, where they wait until the BeforeUpdate event procedure is finished.
    Not sure if it helps you as an Access beginner.
SOURCE:
Hello when i am opening device manager its not opening showing some error mmc console error
Hi Welcome to FixYa!
You could try different steps below on how to fix this problem.
1)You could download an automatic fix from Microsoft with this link: http://go.microsoft.com/?linkid=9657414
Then click Run in the File Download dialog box, and follow the steps in this wizard.
2) This issue may occur when one or more of the .dll files that are used by the Microsoft Management Console (MMC) are missing or corrupted. These files include the following:
  • Msxml.dll
  • Msxml2.dll
  • Msxml3.dll
To resolve this issue, follow these steps:
  1. Click Start, click Run, type cmd, and then click OK.
  2. At the command prompt, type cd %windir%\system32, and then press ENTER.
    Note The %Windir% folder is the folder where you installed Microsoft Windows.
  3. Type the following commands. Press ENTER after each command. Regsvr32 Msxml.dll Regsvr32 Msxml2.dll Regsvr32 Msxml3.dll
  4. Type exit, and then press ENTER to close the Command Prompt window.
  5. Restart the computer.
Hope this would be a big help!
Jun 22, 2011 | Computers & Internet
I have genuine windows 7 but computer says that it is not genuine
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B). Method A: Disable the Plug and Play Policy
1. Determine the source of the policy. To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to "Not Defined." Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy:
1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template
Query status
Enumerate dependents
Interrogate
User-defined control
Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)
(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)
(A;;CCLCSWLOCRRC;;;IU)
(A;;CCLCSWLOCRRC;;;SU)
S:(AU;FA;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;WD)
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to "SU" (SDDL_SERVICE - Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO's in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
  1. On the computer that is out of tolerance, start Registry Editor.
  2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions...
  3. If the NETWORK SERVICE is not present, click Add...
  4. In Enter the object names to select type Network Service and then click Check Names and OK.
  5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
  6. Restart the computer.
  7. After the restart, the system may require activation. Complete the activation.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 13, 2011 | Microsoft Windows 7 Ultimate 32 & 64 BIT
Hwo to instal windows 7
Welcome to FixYa.
Please elaborate your problem providing us with more details.
Thanks for using FixYa.
Nov 26, 2010 | Polaroid FLM-3732 Television
How to create macro button in microsoft excel 2007 because
well follow the steps below to get your job done:
To create an option button in Microsoft Office Excel 2007, make sure that you add Option Button (form control) to the Quick Access Toolbar. To do this, follow these steps:
  1. Click the Microsoft Office Button, and then click Excel Options.
  2. Click the Customize category, select All Commands in the Choose commands from list, select Option Button (form control), and then click OK.
To create an option button and to assign a macro to it, follow these steps:
  1. In Excel 2003 and in earlier versions of Excel, click Option Button on the Forms toolbar, and then draw the outline of the button on the sheet.
    In Excel 2007, click Option Button (form control) on the Quick Access Toolbar, and then draw the outline of the button on the sheet.
  2. Select any cell in the worksheet.
  3. In versions of Excel that are for Microsoft Windows, right-click the option button, and then click Assign Macro.
    In versions of Excel that are for Macintosh, press COMMAND while you click or press CTRL while you click, depending on your operating system version. Then, click Assign Macro.
  4. In the Assign Macro dialog box, click the name of the macro that you want to assign to the option button, and then click OK.
When you click the option button, the macro will run.
good luck ...:-)
Apr 08, 2010 | Microsoft Office Excel 2007
Ans
this is not a sufficient to answer. but, you can get some idea in the following information:
if you have a plan to install AD:
  • install AD using manage your server wizard. (or)
  • install AD using DCPROMO command
After, you have to follow the AD installation instructions to store the ntds and sysvol files.
installing dns, is also need for a domain to adding clients.
after this, you can get your desired domain controller and active director users and computers information.
i think, this may be useful for you.
thanks,
Feb 12, 2009 | Microsoft Windows Server Standard 2003 for...
Microsoft Office Standard for PC Logo
629 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
