Question about Canon Rebel XT / EOS 350D Digital Camera
Lcd panel stays black
The camera shutter is working, but it won't take a photo. We're tied directly to a computer, no card. The lcd screen stays black. Any ideas?
  • quickaspeter Aug 17, 2007
    Didn't work, the ccd is gone. Thanks.
  • 73 Answers
A penlight shined into zoomed back lens - shows if iris is open ( ccd looks like a small xmas tree scene , deep in center ) : if iris is stuck closed , a thorough lens cleaning should restore camera video - if iris is open , the ccd may be or already has failed ;
Posted on Aug 15, 2007
SOURCE:
Why does the screen stay black when camera is turned on?
Did you try to press the display button several times? Most of the time you can cycle through different views on the display, with different information during record mode. One is display off.
Jun 18, 2014 | Olympus FE-340 Digital Camera
Eos 5D lcd screen stays black when power is turned on. It will show menu and review photos taken but otherwise remains black so it will not show what is in front of the lens.
Sounds like the shutter control is not active. If closed, the shutter will not allow light to enter and thus you have a black receptor. Take to a camera shop for testing.
Mar 17, 2014 | Canon EOS-5D Digital Camera
My Canon PowerShot A620 has a black screen, any ideas on how I can fix this? I can't even take pictures, all of them come out black
My A620 JUST started doing the same exact thing last night. LCD works, lens works... but something possibly wrong w/the shutter so it won't open.. everything black.
Jan 05, 2010 | Canon PowerShot A620 Digital Camera
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Black LCD screen. Nothing in LCD screen. No photo on card. When connected to computer, black images appear, no photo. Problem?
I took a hammer to the shutter - now it opens! Actually, I tried the suggestion and it did not correct the problem. I guess I will have to get a new camera. Very disappointed as this camera is only four years old and well cared for.
Jul 31, 2009 | Canon PowerShot A620 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
A95 LCD screen black and unable to take photos
Its common problem in canon cameras and I have solution. please let me know if you didn't find in chat.
Sep 02, 2008 | Canon PowerShot A95 Digital Camera
Won't Take Photo
Hit buttons for the ISO settings on the photo you just took; if the settings are way off, maybe you can correct those or select a mode which gets you a proper image in the LCD; or reset the camera.
I for one wish I would jog the camera to a local shop for free adjustment (e.g. lens reattachment) the first time I ran into symptoms like that. I always let it fester 10 min, though.
May 10, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
LCD Black
sorry I have the same problem. It seems like it is a shutter problem...the shutter is locked closed therefore the screen is black.
Feb 25, 2008 | Konica Minolta DiMAGE E500 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
