Question about Panasonic VDR-D100 DVD Camcorder
Disc eject The device keeps saying the disc door is open, then I open and reshut it, reset the device, and then it says disc door open again. It appears to be closed.
  • cherrycola Aug 15, 2007
    Thanks, wareworlf! Any ideas how to find a service provider?
    Thanks, warewolf! Any ideas how to find a service provider?
    Novelist:
    Scholar:
  • 158 Answers
Sounds like the latch mechinisem for the disc door have it repaired as soon as you can. hope this helps
Posted on Aug 15, 2007
SOURCE:
My samsung HT-C350 won't eject. It keeps saying lock when I press eject.
Hello
Your Samsung HT-C350 is paretial locked. You have to unlock it. If you have forgotten the passcode, do these.
There is no no dic inside I thinks. If there is a disc inside, remove it by by anyway opening the device. If there is a disc inside, the player will show its contents and you can confirm it.
Press and hold STOP button on the remote control for 5 seconds or more. All the settigns will revert to Factory Settings.
OK.
Apr 12, 2011 | Samsung Audio Players & Recorders
My device cant open the disc tray please advise me on what to do
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
Feb 16, 2011 | Audio Players & Recorders
The magazine for my CD 12 disc changer will not eject nor will it play ant CDs. It seems to be getting power as the light inside the slide door lights up as open to eject the magazine any suggestions? It...
theres usually a reset button hidden inside the door on the cd changer. use a paperclip to reset the device. sometimes theres a reset on the controller part of the cd changer Up by the radio ( if you have tha type )
Jul 31, 2010 | Pioneer Car Audio & Video
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
I have a pannasonic DMR-EZ47V VHS/DVD player It has a DVD in the the player when you try to open to remove the disc it says no disc and will not open. Have tryed reset unpugged power from the unit still...
Did you try this? When the unit is on, hold down the power button for 10 seconds or more until the unit powers off. Then, turn the unit back on again. You can try to press the eject key before the unit has time to try to "read."
Dec 07, 2008 | Televison & Video
Won't eject DVD
I was able to fix this problem by disconnecting the Bose power cord from the back of the unit. When I reconnected it the door functioned again. Cleaning the disc helped avoid further lock ups.
Apr 02, 2008 | Bose (321GS) System
Wharfdale dvdr24hd160f
ok
Look at the door of your DVD shutter. There might be very small hole. This is an emergency Shutter open point. Make off your player, insert a long pin inside the hole, press it gently, you will notice that the shutter is openning, pull it out side, and take off your data DVD from the tray.
Thanks
Iqbal
Mar 08, 2008 | Televison & Video
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Feb 22, 2008 | Hitachi DZ-GX3200A DVD Camcorder
Changer refuses to eject or play CDs, keeps saying reset
Hello, in order to repair CD changer you have to be equiped with special tools and knowledge. This repair is only possibble in Authorized Sony Service or at the shop with best references for this kind of job. Best regards, Arpi
Apr 13, 2007 | Sony CDX-656 10-Disc CD Changer
Panasonic VDR-D100 DVD Camcorder Logo
134 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
