FixYa.com
Tags:
Compaq Tablet PC
Forgot password (by 4 users)
posted by wacko012345 on Aug 14, 2007
I forgot the password. How can I login?
Is there something I can do?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Jeffyell6, posted on Dec 06, 2007
i have the same problem but how can i use the bootable cd if the compaq tablets dont have a cd drive...and i have an admin. password set.... so F8 and ctrl+alt+delete doesnt work
Comment by kishan chan, posted on Nov 28, 2007
i have forgot my pc passwordand i cannot open my account.
Comment by hottnthick, posted on Nov 20, 2007
forget system password compaq computer cant load windows
Best Solution
posted on Sep 26, 2007
FixYa! (100)
askanything
Rank:Wiz Wiz
Rating: 84%, 211 votes
you can crack password:
Follow these steps
1) Restart your pc and press F8.
2) Open your pc in safe mode with command prompt.
3) Then go to C:/windows/system32/>
4) type in it this one:
C:/windows/system32/> net user (username) (newpassword)
->in username use the name administrator or username for which u want password
-> dont worry about old password type your new password.
->Login with your new password.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 14, 2007
FixYa! (100)
PCTServices
Rank:Wiz Wiz
Rating: 85%, 244 votes
At the windows login screen hold down alt+control+delete
This will give you a screen where you can type in a username and password
Try this login
Username : Administrator
Password :
Assuming that you did not set an administrator password it will be blank, and you can log right into the system.
Once you do that, simply go to the control panel and then users. You can then click on your username and select the option to delete the current password.
Alternatively you can also attempt to log into safemode by pressing f8 before windows boots, from there you can try to log into administrator as well and remove the password the same way described as above.
If all else fails you can download the ultimate boot cd. It is a bootable cd that has an option to remove some windows xp passwords.
You can find the ultimate boot cd at http://www.ultimatebootcd.com/
Good Luck
Peter
Can you Help with these Tablet PCs problems?
Tablet PCs
sounds and audio device
shah92 rank: Wiz Solved:74 Answer This...
Tablet PCs
Toshiba Satelite r25s35-13...
Security fingerprint files are... Answer This...
Tablet PCs
Problems with Genius G-Pen F350
I just got the tablet and I got... Answer This...
Tablet PCs
Keyboard not recognized
I have 22 Fujitsue Lifebook T... Answer This...
Tablet PCs
Screen Protector
How do I REMOVE the screen... Answer This...
Repair Service
Find Tablet PC Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
