Question about Mitsubishi HS-U778 VHS VCR
Everything's in black & white
I'm attempting to transfer VHS tapes to DVD using a Mitsubishi HS-U778 I bought new but hadn't used before now. Even after adjusting the tracking, I can only get a clear black & white picture, never color. I've tried this on several commercial VHS tapes as well with the same result. Any help will be greatly appreciated! Thanks.
    Novelist:
    Scholar:
  • 158 Answers
Are you using the s video socket if so you will get black & white picture you need to use rca phono to rca phono or rca phono to scart lead to record to dvd burner. as I do alot of copying over myself i never use s-video socket due to cable wrongly wired for colour just black video signal. hope this works for you
Posted on Aug 15, 2007
SOURCE:
How to connect dvd player to vhs
Screw the coaxial cable to the television...then screw in the other end into the antenna in on the vcr....after plug in the audio video plugs according to the colors given (yellow goes to yellow, white or red goes into the white)...then usually it has a switch what channel you wanna use it for....then enjoy!...
May 20, 2012 | Mitsubishi HS-U540 VHS VCR
Mitsubishi HS-U540 VHS VCR How do you connect the red, white, and yellow cables?
The RED is Right Speaker the WHITE is Left Speaker and the YELLOW is for
Video. They connect with RCA Cables to the same color coded inputs on yout TV.
You may find it easlier to just use a CoAxial Cable; Use a CoAxial for the CABLE IN to the Cable Box then 1 CoAxial from the Cable Box OUT to the VCR IN then use 1 OUT from VCR to TV IN. That is much easlier then using RCA Cables.
Aug 14, 2010 | Mitsubishi HS-U540 VHS VCR
We just bought a new 32" panasonic led tv. Hooked everything up and works fine with normal television broadcast. However, we have a Sony DVD/VHS combo hooked up that doesn't perform well. When we play...
If you are using the composite cables (RWY) make sure the red and white are plugged into the audio jacks and NOT the component cable plugs (RGB.) If you have the red audio cable plugged into the red component plug this will cause issues, especially with the sound.
Aug 10, 2010 | Panasonic Televison & Video
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
When I put a tape in my vcr it spits it back out...
this sounds like a cleaning and tape carriage alignment is needed, that not too hard to do if you tinker.Service on this is not too much at electronic or tv repair
Jan 26, 2009 | Mitsubishi HS-U545 VHS VCR
Transferring vhs tapes to dvd on sanyo DVW 6000
I believe that unit is a DVD player only and deos not record to DVD.
Hope that helps...
Geno
Apr 01, 2008 | Sanyo DVW-6000 DVD Player/VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
E2 error
Just had the same E2 come up on my HSU-445. The only thing we could figure out was to try a different tape than the one that was in there when the error came up. That seemed to do the trick. Not sure how long that will work. Good luck.
Jan 11, 2008 | Mitsubishi HS-U445 VHS VCR
VHS tapes are black and white
The tapes are B/W or one of the playback video heads is not making contact with the tape. The video head may need to be adjusted. You can take it in to get it fixed or buy a new one. The unit today is worth around $25-$30.
Jun 25, 2007 | Emerson EWD2202 DVD Player/VCR
E2 error
Something might've been broken in the forced tape removal. VCR tape carriage (the cassette unit) assemblies are rather delicate, easily broken, in contrast to the units in early VCRs (from the '80s or early '90s). Use of force in tape removal... can break stuff, or perhaps get the gear timing fouled up. Take the top cover off, look for broken pieces of this assembly. If this assembly has gears on the right side, this obviously means it is gear driven. Timing is set by lining up marks on the gears, in most cases. Setting this might be tricky- service literature will tell you how to set this, and in what mode the marks line up.
Apr 15, 2007 | Mitsubishi HS-U778 VHS VCR
Mitsubishi HS-U778 VHS VCR Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
