So i have connected my mp3 player into the audio bus in input on my headunit,,, i get nothing nor can i select the input. do you know of any solution to this problem?
SOURCE: Linking an i pod to a Sony CDX-MP40 using the bus input terminal
Some Sony head units let you use the Bus audio inputs as an auxiliary source input, but yours is not among them. To play your iPod through the head unit, you'll either need an iPod interface module: http://www.xplodsony.com/xplod/accessories/XA-110IP or an auxiliary input module: http://www.xplodsony.com/xplod/accessories/XA-300 The iPod interface will allow you to control and display the iPod directly through the head unit, while an auxiliary input adapter will allow the iPod to play through the head unit using the iPod's controls and display.
SOURCE: sony cdx mp40 bus audio in
ok dont know if you will check up on this but fm transmitters are all garbage. for true undistorted sound go to an electronics store and ask for a rca to headphone cable. then just hook it up to the rca input and run the cable out of either the unit or somewhere on the dash. this will alow for a true connection and if you buy a brand name cable i.e. monster, radioshack, sony etc. should sound amazing. always happy to help.
big c
SOURCE: Cannot play my portable audio device with Sony cdx c500x
The multichanger has to be connected,with a cd in, but then the head unit will play whatever is fed to the bus in sockets. This effectively means the multichanger is playing to itself. If you want both to work, use a pair of piggy back rca leads into the head unit, one to the cd, one to the mp3. Then break into the cd leads and feed one of the pairs, one +ve, one -ve to a double pole switch so that you cut the sound from the cd allowing the mp3 in. To play cd's, flick the switch.
SOURCE: can i connect a mp3 player to my sony cdx F5500.
Yes you can. You will need to get an RF adapter and connect it using the antenna or an RF adapter that send out a signal and tuen your radio with either one.
i have the same problem
have you been able to solve this?
Same as described, different cd player though.
I can not select Aux with source, only FM, also no FM, it reads but no sound or reception
