Question about Kenmore 64802 Top Freezer Refrigerator
Not cooling my refrigerator fan is running but the fridge and freezer are cooling very slowly and not freezing ice.
  • candy21 Jun 05, 2008
    Between the door and freezer is very hot and the freezer is not freezing well and the lower part is not cooling the way it should.
    Scholar:
  • 42 Answers
If you still have this problem I would like for you to check to see if the fan below the refrigerator is blowing. This fan is called the condenser fan and is located beside the compressor in bottom rear under the refrigerator. If it is not running It may have a piece of paper or mouse or something lodged in the blade or it may just have bad motor bearings. If you use an exterior fan to blow air under the refrigerator it will cool again till you can replace the bad condenser fan motor.
supertechks
Posted on Nov 22, 2007
SOURCE:
Fan is running but the fridge is not cooling at all
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Jul 11, 2011 | Maytag 22.1 cu. ft. Bottom Freezer...
Freeze doesn't freeze and fan in fridge is now making noise
Usually when the fan in the freezer is making noise it is because there is ice built up and it is hitting the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Samsung RB1955VQ Bottom Freezer...
Freezer is cooling, but refrigator is not cooling
take a look at your evaporator fan motor in the freezer to make sure it is running and not built up with ice around it. this fan motor pushes the cold air from the freezer into the fridge to cool the fridge. you say the freezer is "cooling" , is it freezing??
Oct 14, 2009 | Hotpoint Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer fan
actually, freezer fan has to come on otherwise how is the fridge supposed to cool.(fridge draws off from the freezer compartment). check if there is power to the fan. if freezer is nice and cold and fan does not run(assuming there is no power to the fan at that time, then you would need to check your freezer thermistors after that, your board. all this is assuming you dont have a blockage or shortage of gas in the sustem.
Sep 20, 2007 | Kenmore 72293 - Stainless Steel Top...
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
136 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
