The fan, light, clock, minutes, countdown all work but no noise like a motor not running.
SOURCE: display panel works but no heat, no fan, turn table doesn't turn
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: Microve turns on, but will not heat Model number is FMT148G1B2
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven.
Most people don't, for this reason, replace the magnetron, they replace
the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the
magnetron is faulty and you need to take it apart, find the proper
electrical leads and test them with a volt meter. To do this you have
to remove it from its mounting and take it apart. It is a fairly
lengthy process however.
Benjamin
Benjamin
SOURCE: My KCMS185JSS-5 microwave has no heat. It seems to
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
