Question about Indesit 24 in. DI67 Free-standing Dishwasher
Indesit di67 dishwasher
I have the above model dishwasher. All worked fine until this morning when i closed the door, turned the control knob to reset, got the beep - then switched the machine to program 1. I get the usual noises (ie - it sounds like its trying to drain & then fill up) but thats it. It tries for about 30sec then does nothing. Ive checked the water supply & all is fine & took the water inlet pipe off, poked around the inlet which all seems clear. In addition, I took the bottom washing arm off, put a small pipe into the vale & blew & sucked to see if any blockage would clear - STILL nothing!! Anyone with any ideas or experince of this -ta!
  • 725 Answers
Re: Indesit di67 dishwasher
Did you check the float switch? it is bottom of the dishwasher ( may be under the dish washer Bosch / Danby .. it should move freely up and down.. make sure that there is not something under it .. Also to much soap can stick the the float in the up position. if it moves freely test it. unplug the dishwasher or shut off the power at the breaker. Check for continuity with the terminals removed...if you don't have it you have a bad switch...let me know if it helps
Posted on Aug 15, 2007
0 characters
3 Points
Indesit D63 stops mid cycle
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 21, 2008 | Indesit 24 in. D63 Free-standing...
Need manual for indesit dishwasher d1620 please
Visit this link to download the Dishwashers DI620 User Guide (pdf format)
Hope this helps (remember to rate this answer).
Jul 07, 2011 | Indesit 24 in. DI67 Free-standing...
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Indesit Dishwasher DI67.Cycle phase lights(prewash and wash)flash
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
Feb 28, 2008 | Indesit 24 in. DI67 Free-standing...
Indesit 24 in. DI67
Hi there
I have had this problem before. If your dishwasher is not level water collects at the front. Try tilting your machine forwards. Be carefull though as water will come out of the bottom. Once you have done this and reset your machine it should be ok.
Jan 12, 2008 | Indesit 24 in. DI67 Free-standing...
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Di67 s dishwasher
Try tilting your dishwasher forwards. Be warned that water will escape from the front. I have had this problem and paid an engineer to come and tell me this. If your machine is not completely level water collects at the front and does not empty. This then causes the machine not to work. Good Luck
Dec 18, 2007 | Indesit 24 in. DI67 Free-standing...
Indeset di67
this can either be the dispenser itself or the module which drives it. for a start, split the door and check continuity thro the dispensor coil. can also be caused by the plastic parts distorting. actuate manually and see if door flys open
Apr 27, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit 24 in. DI67 Free-standing Dishwasher Logo
606 people viewed this question
Top Indesit Dishwashers Experts
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
