Question about Zebra Eltron LP 2824 Thermal Printer
Slow printing to LP2824
Have a Zebra LP2824 connected to a JetDirect printserver, takes about 2 min to spool a simple label to the printer
  • 1 more comment
  • Anonymous Mar 13, 2014
    lP2824 STOPPED PRINTING AFTER LABEL CHANGE
  • Anonymous Mar 24, 2014
    I am trying to print from my zebra LP2824 and it just won't respond. The light around the feed button is flashing red then green. It has been like this for two days now. I have tried restarting, disconnecting and connecting the cords. I have gone through the trouble shooting process on the computer and it says it is processing a "firm download"
    any ideas?
  • Anonymous Mar 31, 2014
    power button turns red
This appears to be normal operation.
Posted on Nov 06, 2007
My zebra lp2824 barcode printer does not print, i downloaded zebra lp 2824 from nice label still it not working, when doing print test it will print only some letters....what to do
check the driver, and the setings from the driver. Try ZDesign Driver or seggul driver from WWW.seaguscientific.com, and print the testpage, chech the connection (port) if is seria (com) check the setings speed etc...
Nov 09, 2010 | Zebra Eltron LP 2824 Thermal Printer
ZEbra 105SL. How can I install it on a printer server? Which port should I use when asked for in "create new port" option using the add printer wizard?
external printserver? on the printer is PARALEL PORT, press withe button from the printserver to print net config. label, then go to create new port, write the IP adress...
Sep 14, 2010 | Zebra 105SL Thermal Label Printer
We relocated our Zebra S4M to the new area and it
Have you tried resetting the printserver? I am assuming this is a networked printer when you say the red light on the back. There is a little button on the printserver. Turn printer off, and while pressing that little button in with a paperclip, turn the printer on and continue holding in the button until the light is a solid green. Could take a minute or two depending on the network.
Oct 06, 2009 | Zebra S4M Thermal Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
My zebra LP2824 Thermal printer is driving me nutty. It skips tags between each printed one. I'm printing on thermal labels that are 1.1875x3.375 (2 side by side) so the total measurements are 2.375x3.375....
possible is not the best printer to work on site-by site labels because the sensors that read the gab are on the midle of the label and possible can't check wen the label start and end. try the printer S4M (sensors on lenf side), or try normal labels and press the botton until flash 2 times and release the botton (calibrate).
Dec 14, 2008 | Zebra TLP 2824 Printer
LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra Eltron LP 2824 Thermal Printer Logo
486 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Joaquim Martins
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
