Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Convection oven not working properly???
I've never had a convection oven before but I don't think my new oven one is working properly. I put a casserole in set for 400 degree for 30 minutes. It was barely warm. I change to regular bake, same temp and time and it cooked just fine. I noticed that when I cancelled the convection bake and started the regular bake it preheated from 300 degrees. I know that the over automatically reduces the temp by 25 degress in convection but it seems to me that it only got to 300 degrees ?? I'm pretty sure that the fan runs. Any ideas?
  • 4 more comments
  • luadams Aug 15, 2007
    I watched the fan thru the glass door and it appeared to "stutter". Like it was trying to work. I opened the door and gave the fan blades a bit of "help" by spinning it.
    It nows spins steadily but it seems really slow to me. How can I now if it's spinning at the speed it's supposed to be or even close. Shouldn't it be spinning really fast?
  • luadams Aug 16, 2007
    I've used the oven twice in the traditional bake mode and tried to use the convection mode twice. As far as I'm concerned it is still brand new since the convection oven never baked anything.
    Knowing this do you still think the start switch is bad?
  • luadams Aug 17, 2007
    Are you not reading my responses?
    I told you that I've used the oven a total of 4 times. Period. Twice traditional mode then twice in convection mode.
  • Anonymous Mar 18, 2014
    the oven light keeps flashing on and off. I was baking something at 400 degrees and it started flashing. what does this mean?
  • Anonymous Mar 28, 2014
    .when you hit keypad it double dings but will not let you set temp or anything else
  • 640 Answers
Your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Posted on Aug 15, 2007
  • 2 more comments
  • anthony james
    anthony james Aug 16, 2007
    the start switch is bad in the motor.how old is your oven?another thing to check is make sure the fan blade isnt just spinning on the motor shaft{there may be a set screw that holds the blade to the shaft so its not loose}.if thats not the case you need a motor.
  • anthony james
    anthony james Aug 17, 2007
    from everything you told me i still belive the motor is bad.is the oven under warranty?if you definitely seen the blades 'stutter' and pushed the blades and they started working but not as fast.MOTOR MOTOR
  • anthony james
    if you rarely use the convection mode the motor still gets hot from the heat of the oven regardless what mode your in.and prematurely motor failure.
  • anthony james
    anthony james Aug 18, 2007
    its the motor.they can be defective straight from the factory.i couldnt count how many times this has happened to me in my line of work.again you should have a warranty since you only used it 4 times.
GE JVM1790WK convection microwave
I assume you've referred to your owner's manual to be sure you are operating the convection properly?
If for some reason you don't still have your owner's manual, you can get it here. See the tips on page page 30.
You can also do a hard reset by unplugging the oven for a couple of minutes, plugging it back in, then setting the clock and trying again.
If it's still not working, you may have a bad sensor or other problem.
Sep 04, 2012 | GE JE1590 Convection / Microwave Oven
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Fridgidaire Wall Oven will not heat
1) If there is a reset on the electronic panel try that.
2) Set the temperature to 200 and see if works then.
3) Put a baking tin in the oven with a piece of meat in it.
4) Uninstall the Wall Oven and take the back off and check the wiring for the elements and the convection fan.
Jan 13, 2018 | Frigidaire 30 in. Electric Gallery Series...
Dacor oven overheating
sounds like your bake relay is not closing
you need service relay board replaced
Aug 01, 2017 | Dacor Preference PGR30SS Gas Kitchen Range
My GE Profile Convection Microwave Oven - Convection not working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uijjf
Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
Preheat gets to temp but oven drops 20 d+/- after food goes in. Is this normal
You may have already solved this but either your convection motor is not on or you have an air leak. I would get the repair man out since it is probablt still under warranty.
Oct 24, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
Never used Convection JTP 5650DI55
Did you try going to the GE website? If not, try it:
http://www.geappliances.com/
When you pull up the website, you can click on the blue down arrow located in the box at the top of the web page, next to the work SEARCH and click on "USE & CARE MANUALS. Put your model number into the next box to the right and hit GO.
If you are having trouble after entering what you believe is the proper model/serial number, you can look at the FAQ (frequently asked questions) section to determine whether you have actually entered the proper number.
Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
Oven issues
replace the oven ignighter
Feb 26, 2008 | Kitchen Ranges
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Model #JMW9527CAQ convection oven has no display visible.Started out very dim and eventually went to no display on the front display .
Aug 17, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
1,531 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
