Question about JVC GR-D20 Mini DV Digital Camcorder
Jvc digital video camcorder gr-d20ek no power
Battery pack has charge. i have no power whatsoever in my camcorder. when i use my ac power adapter the power/charging light does not come on.i have tried a new battery ,still no joy.please can someone help.
  • 1 more comment
  • chiv Aug 20, 2007
    my mini cassette is inside this camcorder. i have no power whatsoever.i cannot get my cassette out.cassete cannot be removed without power. please help.
  • Anonymous Jul 08, 2008
    Exactly the same problem
  • markp37138
    markp37138 Jan 30, 2014
    same problem
  • 30 Answers
Wipe the contacts with after shave solution or isoprophyle alcohol, this may do some magic
Posted on Aug 15, 2007
  • paul tidswell
    paul tidswell Mar 25, 2014
    thanks i will try that
  • paul tidswell
    tried that but it didnt work
    New Friend:
I heb probleem ook gehad.
Oplossing heb ik gevonden kost niet meer dan € 30.00 stuur een mail naar.
[email protected]
Posted on Jul 28, 2011
6ya staff
SOURCE:
I want to transfer my Video tapes from a JVC Camcorder GR-D20EK to my Windows PC. Then burn them onto a disc..can it be done?
You can get hardware and software to do this, often as a kit. Radio Shack or Maplins may be able to help, or alternatively Ebay or Amazon.
Mar 01, 2016 | JVC Video Cameras
How do u reset jvc camcorder
Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the A position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
Nov 30, 2010 | JVC GR-SXM240U Camcorder
How do you recharge battery where is the plug grd850u
almost all this dv cameras have a AC adapter and internal data battery so just plug the ac adapter and the battery will display when it is full ...it doesnt even need to be on when charging ...
Feb 27, 2010 | JVC GR-D370 High-Band Digital Video Camera...
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
No picture
The ccd base assy. needs replacing.
Jun 29, 2008 | JVC GR-D20EK Camcorder
JVC Camcorder - used wrong power lead to charge battery
There is a circuite protector near by the connector which is coming from the battery to mainboard.Just replace the same.
Nov 15, 2007 | JVC GR-D20EK Camcorder
GR-D90 no turn on
Hi, if you can be sure that your adapter or battery is good , your camcorder has internal problems, time to see a technician.
Aug 31, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
How to find replacement adapter for GR-D70AS
Order the original adapter from JVC. The adapter supplies the correct current requirements to operate the battery charge circuit. JVC's web site is JVC.COM. The correct charger will provide up to 1.5 amperes of current for the charge circuit at approx. 11 volts DC. Good Luck Joe Weibel Custom Electronics (customelectronics.org)
Feb 10, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Charging battaries oversea.
The battery chargers that are included with JVC camcorders sold in the U.S. are designed to operate on power from 110 to 240 Volts at 50 or 60 Cycles AC. All that is needed to use the battery charger overseas is a plug adapter to connect into a foreign electrical outlet. These are generally available from a store which carries electrical supplies.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GR-D20 Mini DV Digital Camcorder Logo
528 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
