It is a diamond stealth graphics accelerator card featuring radeon 6250 and im unable to get it working properly cuz its not installing proplerly. ive uninstalled it and re-installed it and im have the same problem. the card just doesnt seam to produce an image but when i plug it back into the on board video card the monitor cums back on and everything is 10x the normal size
Does your tower support PCI?
Is the card PCI, and not PCIe? (There's a big difference)
If you've installed the drivers and software that came with the video card, and still get no picture, you may have a defective product. However, try this, to rule that out.
Once in your PC, and your monitor's connected, try the "Source" button on your monitor. It's possible that your old video card used analog, and your new one uses digital, and your monitor just needs to look at the right input.
If that doesn't work, and you've installed the software, you may want to contact Radeon to replace the unit. Or, return it to the store to exchange for a new one, if you're within your return period.
Do you know what type of cable you're using to hook your monitor us? Is it DVI, HDMI, or VGA?
If your monitor has only one input, and your video card has the same one, you may have a defective video card, and need to exchange it.
So the monitor has a built in DVI cable? That seems unlikely, but possible.
Do you have an alternate monitor you can try that supports DVI?
thanks ill try that and i got the card monday
there isnt a source button on my monitor but there is a menu button but it doesnt have an analog/digital setting
dvi card. the monitor has a cable that is perminent so i cant change cables
