Question about LG WM-1480FHD Front Load Washer
Suspect drum bearings
I need advice on how to replace the drum bearings on an LG WM 1480FHD washing machine and what if any replacement seals will be needed. Information on where a service manual can be obtained would be extremely useful.
  • NDT228 Mar 14, 2008
    My WM-1460FHD is noisy when spinning, and slight movement of drum is possible when stopped - pretty sure bearings need changing. Can get spares, just need to know how to fit them. Why no service manuals available ?
    THANKS
    nICK
  • Anonymous Mar 25, 2014
    need to replace drum bearings information on stripping
  • LG Master
  • 909 Answers
Most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Posted on Aug 16, 2007
  • TonyElyod Mar 02, 2011
    Having just replaced the bearings myself My LG Machine is now working as NEW.
    I can now balance a coin on the top without it falling over.
    It no longer sounds like a BOEING 747....crash landing.........
    If you want FULL IN-DEPTH details
Hi I have same washer can't hear myself think when it spins are the bearings easy too change?
Posted on Jan 19, 2012
SOURCE:
Wash cycle works ok but will not spin and oe appears in digital display then it switches off. We have just had drum and shaft and bearings replaced, repair man ran it then when we trid to use it it has...
This is what "OE" Means :
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Feb 09, 2011 | LG Washing Machines
I have LG WFT70A37ECT top loading washing machin. getting dE error even though door is close, what is the other reason
How many years is yoru washing machine? I suspect bthe magnet on the lid of the washer has probabkly come off which causes the washer not to identify that the door is closed. U need to replace a magnet on the lid.
Oct 17, 2010 | LG WM-1480FHD Front Load Washer
When spinning making a loud noise
you can check the damage on axis bearing Bosch, exactly is behind close to the fan belt pulley. You have to replace it.
Jul 26, 2010 | LG WM-1480FHD Front Load Washer
How do you change drum bearing on lg wm-1290fhb washing machine
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
Apr 05, 2010 | LG WM-1290FHB Front Load Washer
Having trouble separateing drum from tub to replace bearings on LG wm1480. Do I need to use a puller?
Use a rubber mallet or an oak block to cushion the hammer blows. Be careful not to bend the shaft or your drum will wobble. Also don't ding the spline on the shaft.
Jan 11, 2010 | LG WM-1480FHD Front Load Washer
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
LG washing machine smelly drum
try the hotest wash not on a quick wash and put a hand full of soda crystas in the drum. you can buy these at most supermarkets.
Feb 15, 2008 | LG WM-1480FHD Front Load Washer
LG WM-1480FHD Bearings help.......please
ACTUALLY CREEKY WITH BEARING AND SEAL REMOVAL, YOU NEED CERTAIN TOOLS AND KNOWLAGE CONCERNING THE PROCEEDURE. TO DO IT AS A D.I.Y.REPAIR ONCE OFF IS POSSIBLY NOT VIABLE DUE TO DEFINITE DAMAGE WHICH WILL OCCUR. SUGGEST A TECH.
Aug 09, 2007 | LG WM-1480FHD Front Load Washer
LG WM-1480FHD Front Load Washer Logo
813 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
