1996 Honda CBR 600 F(3)T Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery i have a honda cbr 600 f3. i put a new battery in it and drove 33 miles. when i tried to start it again the battery was drained. where should i start.
  • jmartinuhc Mar 20, 2009
    thanks Mitchy123 it was a park light
Anonymous
Level 2:
  • Expert 216 Answers
  • Posted on Mar 18, 2009
Anonymous
Expert
Level 2:
Answers
216
Questions
Helped
121023
Points
559
Two things can be happening, either your charging system isnt doin the job, or you have a short thats draining yer system... so
to answer your question... start by fully charging your battery, then put a volt meter on it and turn your bike on.... the volt reading should increase.... if it doesnt - you got a stator or regulator problem - if it does..... you need to trace your wires for a possible ground to yer frame
  • Anonymous Mar 20, 2009
    Good going ... Thanks for the feed back
I HAVE A 98 HONDA CBR 600 F3 I CHANGE THE STATOR AND CHANGED THE RECTIFIER AND I STILL DRAINS MY BATTERY QUICK I DONT KNOW WHAT TO DO NO PLEASE HELP
put a volt meter across the battery, engine stopped must be over 12v.
rev the engine to 3-4000 should rise to about 14v, this will show the charge system is working
Some batteries only last 12 months or so. if it is a couple of years old buy a new one, the gel ones seem to last longer
1helpful
I got a 2008 cbr 600 rr I put 3 new battery on it and they keep going dead they are kinda cheap battery my bike will run abt 2 hour on a new battery then it goes dead and wont push start and it makes a...
Put a charger on the battery for two or three hours. Now start the bike up and use a voltmeter to measure the voltage across the two battery terminals while the engine is running around 2000 rpm. The meter should read around 14 volts. If not, the charging system needs to be checked. If the charging system is working properly then yes, something is draining the battery. You will need to check all the wiring and switches to locate the source.
How much oil do i put in my 1997 honda cbr 600 f3 for an oil change
3.5 US quarts or 2.9 Imperial quarts 10w-40 or 20w-50 JASO MA certified motorcycle oil
My 1997 Honda Cbr f3 acts like it running out of gas
i have a '98 f3 stuntbike. they are very tempermental with air intake. make sure your air filter is clean and induction to the engine not clogged.
2helpful
2answers
My 95 f3 will crank but wont start. everything was working fine replace a headlight now it wont start with the starter. battery is charged and i can push start it but the engine just cranks and cranks and...
Sounds like a wire or plug got disconnected while changing the headlight out, the harness that connects to the clutch safety switch, the one that lets the ignition fire when cranking only when the clutch is pulled in. A safety feature so you don't dump the bike if you crank it while in gear.
2answers
96 honda cbr 600 f3
hi would be good idear to also check spark and and timing also if you just got bike give it a good service this includes fuel filter
hope this helps
3helpful
2answers
Fuse panal
I have a 1995 cbr 600 f3. The main fuse is found by following the positive terminal wire to a relay. It is a box with a red fuse cap on top, in a rubber casing right behind the battery.
Oil filter
there isn't a 99 cbr 600 f3. the f3 ran from 95 thru 98
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
