Question about Indesit W 123 Front Load Washer
Showing error code f-o2 HELP!!!
Showing error code f-02 HELP!!!!
    Novelist:
    Champion:
  • 244 Answers
F-02 should be your carbon brushes which are situated on your motor they are plastic with 1 wire going into each 1 there is 2,1 on either side of your motor
Posted on Aug 15, 2007
SOURCE:
I have a PO171 code on my 1999 Jeep grand cherakee larado can You tell me how to fix it, Thank You.
  • Dale, code P0171 fuel system too lean
  • Possible causes
  • change fuel filter first, if it has not been done recently
RESTRICTED FUEL SUPPLY LINE
FUEL PUMP INLET STRAINER PLUGGED
FUEL PUMP MODULE
O2 SENSOR
O2 SENSOR SIGNAL CIRCUIT SHORTED TO GROUND
O2 SENSOR HEATER OPERATION
TPS VOLTAGE GREATER THAN 0.92 VOLTS WITH THROTTLE CLOSED
TP SENSOR SWEEP
MAP SENSOR OPERATION
ECT SENSOR OPERATION
ENGINE MECHANICAL PROBLEM
FUEL FILTER/PRESSURE REGULATOR (HIGH)
PCM
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2000 Jeep Grand Cherokee p0171
Possible problems related to Code P0171 Jeep Garage Jeep Forum
P0171 System to Lean Bank 1
Code P0171
Mar 11, 2016 | Cars & Trucks
98 ford escort o2 sensor has been replaced but warning light continues to come on WHY?
What warning light is coming on?
What error codes are showing?
Have you reset the error codes?
May 23, 2015 | 1998 Ford Escort
Where are the o2 sensors located?
old post
no codes (all) posted.
so no answers.
and o2 errors have 4 possible reasons, but no code, no JOY
and a front and rear 02.
that too unstated.
Jun 12, 2014 | 2009 Suzuki SX4 2.0
Code p0170
What year vehicle ? mass air flow or speed density fuel control . Do you have a scan tool that can view sensor data . What are the fuel trims ( short & long term ) showing ? PCM problem ? O2 sensors stuck lean , adding propane , do the O2 sensors go rich ?
Jan 10, 2018 | Chrysler Town & Country Cars & Trucks
Error code P0135 O2 sensor heater circuit malfunction, where is sensor heater? Chevy 2003 suburban
It is the o2 sensor itself replace 02 sensor. Keep in mind you have four of them. the computer will tell you which one has the fault example. bank 1 sensor 2 If I can help anymore please repost with engine size I will be happy to help DRIVE SAFE TIM
Feb 19, 2010 | 2003 Chevrolet Suburban
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Please Help... p0404 and p0137 Error Codes (1999 Saturn SL1)
yes egr valve is a common thing on this saturn. very pricy and yes you need the rear o2 sensor good luck i have a used egr if interested off a sl2
Sep 29, 2008 | 1993 Saturn SL1
Indesit W 123 Front Load Washer Logo
242 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
