Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Flickering lines and the color is off
I have this camera Canon S400 for about 3 years, now is showing on screen flickering lines, and the picture is off color (purple), there is anything that can be done to solve the problem? It has been a beautiful camera, was never dropped.
  • 1 more comment
  • afawad Nov 15, 2007
    The problem is the same. However, if you keep on clicking the display button you can at time get the problem cleared and also make it re-appear. If you shine a light in the lens with the camera ON you can see a disc appear and disappear with the clicking of the display. The probabilities are that either there is a loose connection or the disc that rotates is sticking. Hopefully this should be a simple repair/ service issue requiring adjustments. Will someone from anon take on this.
  • Anonymous Nov 18, 2007
    i have the same flickering problem thing. but now it's worse. after 3 months of the flickering and off color problems, now the display monitor doesn't show anything at all, just blank with a little bit of blinking at a time.how's that?
  • Jim_Martinco Nov 21, 2007
    My LCD display will sometimes go purple appear to run as if it were wet, starting in the center. It was intermittent for a while, now constant. Switching to playback mode the LCD looks fine. When the display first starts going purple I can still take good photos. After it's been on a few minutes, even the pix are bad. I've tried bumping it, running through the display options, switching from Playback to Record, changing batteries. Nothing helps. It does seem to be heat related.The Canon support page someone else gave a link to is down. :( Tomorrow I am going to open it up and look for a bad connection. It's a good thing this happened after I bought an S5 or I would have gone for a different brand. My S400 looks new and has never been abused.
Http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=813&modelid=8777&keycode=2112&id=29819
It has been confirmed that the connecting parts of the internal wiring of the CCD used in affected products may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments. If this occurs, the signal is not output from the CCD normally in Shooting Mode, which may cause a distorted image or the absence of an image. This malfunction can be confirmed on the LCD monitor screen during shooting. The same malfunction also appears on the recorded image.
Canon's Response:
Effective immediately, and regardless of warranty status, Canon will repair, free of charge, the products listed above exhibiting the above-mentioned malfunction if Canon determines that the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to carecenter@cits.canon.com
This information is for residents of the United States of America and Puerto Rico only. If you do not reside in the USA or Puerto Rico, please contact the Canon Customer Support Center in your region.
Posted on Nov 22, 2007
  • 1 more comment
  • Jim_Martinco Nov 26, 2007
    I just called Canon tech support at 800-828-4040. We verified the LCD display is okay, because menus display properly, only images generated by the CCD seem to run and turn purple. Canon is emailing a form for me to fill out and enclose with the camera and a prepaid UPS shipping label. I provide the box. I was asked to remove the battery, CF card and strap before sending it in. The tech said it would take 2 to 2-1/2 weeks to repair the camera.
    Needless to say I'm very happy as I like the camera, and I am very pleased with Canon as well.
  • Jim_Martinco Dec 03, 2007
    Just got this email from Canon: "
    We have received your equipment for evaluation and repair. Based on our initial
    examination, we will start the necessary repairs at no charge to you. You can
    expect the repair to be completed and returned back to you within approximately
    7 business days* from the date shown above."
    Hurrah for Canon!
  • Jim_Martinco Dec 07, 2007
    I sent my S400 to Canon on Nov 27, 2007, using the UPS label they supplied. They received it on the 29th. I got it back today, via FedEx 2nd Day, and it works perfectly. Their note said they checked everything else and restored it to "Factory condition." I believe it, because the motor that extends and retracts the lens is about 20 dB quieter. Very pleased, especially as I only bought the camera on eBay a little more than a month ago, but Canon doesn't care about warranty status. Thanks to FixYa for helping fix me up!
I found the same problem recently, but it is intemittent. It then changed from flickering lines to more of a blurred picture on the LED screen. I have tried all things to clear it, but the best seems to be to turn it off for a while and it often clears. Previously captured pictures review fine on the LED screen, but when the screen blurs (with a blurry motion too!) that is how the picture records and reviews. I bought my Ixus 400 in Sep 03 and this problem started in Jun 07.
Posted on Oct 08, 2007
Sent my a80 in for this same issue and Canon fixed it for free plus free shipping both ways.
Posted on Jun 02, 2008
  • Canon Master
  • 4,738 Answers
All your problems sound like defective CCD imagers. If so, Canon should fix this for you for free, including free shipping both ways. I've already had two cameras fixed this way (I collect Canon's, what can I say :). This is regardless of your camera's warranty status! Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Anybody get the camera to Canon for fixing about this issue yet?
Thanks
Posted on Nov 20, 2007
Found the solution on the Canon website. This is a CCD manufacturing defect and Canon is repairing this free of charge. Pls visit the following linkhttp://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Posted on Nov 15, 2007
I have the same problem, and canon is recalling the camera for this issue.
http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=223&modelid=8777
Posted on Oct 30, 2007
Screen flickers and pictures have lines across them on my lumix DMC-TZ3
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
Apr 08, 2016 | Panasonic Lumix DMC-TZ3 Digital Camera
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
Lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Dec 23, 2009 | Canon PowerShot A85 Digital Camera
Unrecognizable pictures with little color and horizontal lines
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Jun 09, 2009 | Canon PowerShot A95 Digital Camera
Canon power shot S400
Dec 26, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Cannot take pictures
Sounds like you might be in luck. These symptoms sound very much like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Apr 21, 2008 | Canon PowerShot A70 Digital Camera
Image on LCD jumps
Apr 09, 2008 | Canon PowerShot A95 Digital Camera
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
313 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
