Question about HHB CDR850 CD Recorder
About the HHB CDR 850 compact disc Recorder
I bin have trouble with my HHB CDR 850 recorder. It?s not recognizing the CD?s, so it?s not working when I first got it, this was the problem from the beginning? what is it I need to do? Someone please get back to me ASAP about the problem. I?ve tried using air in a can opening up the recorder and blowing it out and that work for about a week then it was back to the same problem? and when I try blowing it out again nothing?. Again what should I do?
  • Anonymous Feb 05, 2009
    Same problem. Spoke to HHB informed me problem could be servo board if so then this can longer be obtained hence the machine is scrap stating that high speed recording may have burnt out system. But they woukd need to see the machine and test it.
    Other repairers I spoke to said it may be the Laser but HHB will not supply others with replacement and its cost is around £100 plus labour.
    Only solution to find a company other than HHB who supply spares at a resonable price.
    Anyone know suppliers please post.
  • 112 Answers
You may need a new laser - it's a sony unit inside.
Posted on Dec 09, 2007
SOURCE:
Disc types that have worked for recording in the past are getting a "Not Audio" error upon reading. Specifically HHB CDR80's.
hi, i would try not using cdr discs. alot of older decks had issues reading "r"discs try cd'made for music not data. that should fix u up.
Apr 19, 2016 | Yamaha Natural Sound Cd Recorder Cdr S1000...
HHB CDR 850-No laser lit up...shouldn;t there be light ie. laser
YesI when the unit is first turned on the laser will emit a red light when scaning, if no beam is present it is time to replace your player, not cost effective to repair.
Mar 05, 2012 | HHB CDR850 CD Recorder
Need owner's manual for HHB CDR-850 Where is reoaur cebter?
what is it you need? what is reoaur cebter? I have the machine and manual. My recorder died last night after 10 years. very disappointed!
Aug 07, 2010 | HHB CDR850 CD Recorder
Tengo problemas con el aire acondicionado esta tirando aire muy caliente aunque este en aire acondicionado.
Ok tienes que revisar si el compresor trabaja cuando activas el interruptor del aire si el compresor no se activa podria ser que le falte freon 134a al sitema,que tengas algun problema electrico.puedes comprobar el nivel de freon con un manometro si este esta bien tienes que revisar la parte electrica. Gracias
May 03, 2010 | 2002 Kia Sedona
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
Noise / Hum in recordings
hi, i once had the same problem with a kenwood cassette deck. it would play pre-recorded tapes perfectly but when it came to recording from another source i would get an annoying hum when playing back the recording, the fault turned out to be a faulty earth connection on the phono connectors on the rear, they were dry jointed and once resoldered the unit worked and the recordings were perfect. maybe you have the same problem? hope this helps?
Feb 14, 2009 | HHB CDR850 CD Recorder
Denon CDR-W1500 not recording
I had the exact problem and could not get any of the CR-Rs that I had to work. I looked up the code in the user's manual where it said the error means it's not a recordable audio CD and to refer to page 6. I looked at the front of the manual and saw that it mentions that the CD-Rs must be audio CD-R discs. I did some research online and found that there are in fact differences between CD-Rs that are just marked that and those marked as Audio or Music CD-Rs. I bought a set of CD-Rs that clearly had marked "Compact Disc Digital Audio Recordable" on the package. When I inserted this disc, I had no problems getting the recording to work. So, make sure the discs you use are clearly marked "Audio" or "Music". A computer burner won't know the difference, but your Denon recorder will.
Jan 27, 2009 | Denon CDR-W1500 2-Disc CD Recorder
HHB 850 needs repair
You can contact HHB service team on 020 8962 5000. Or visit their web site and go to support and complete an equipment repair form and they'l get back to you. You can also email the engineers whose names are listed in the contact section. Web site is http://www.hhb.co.uk/hhb/uk/support. Hope it helps
Dec 26, 2008 | HHB CDR850 CD Recorder
RCA CD recorder/player CDRW120
You sure it's recognizing the CDR? And you are using 'consumer audio' cdr? Watch it at all times. If it 'opc fails' after you put a blank in it still shows as a CDR and 0:00 on the display but won't record. It's easy to miss.
Nov 02, 2007 | RCA CDRW120 2-Disc CD Recorder
Recorder not recognizing blank media
To fix this problem, buy CD-R Blanks with word MUSIC CD-R MUSIC
Aug 28, 2007 | KLH CDR2000 2-Disc CD Recorder
HHB CDR850 CD Recorder Logo
530 people viewed this question
Top HHB Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
