Question about Sharp R-1460 Microwave Oven
Sharp R1480 OTR microwave night and work light won't turn on
Changed bulbs, niether will work. one of the lights acted funny (on off erratic) just before failure. I thought the filament was loose, but issems as a control board problem. 115 VAC is at both sockets. Any help? THx
  • 1 more comment
  • lightless Aug 16, 2007
    OK, I took out the sockets. There is ALWAYS 115 VAC present, the instant the unit is plugged in. When I operate the fan, I hear the panel beeps, and also the relay clicks. When I operate either light control, I hear thr panel beeps, but no relay switching noise
    still lightless :(
    UPDATE-
    put the two light sockets back in, and plugged the unit back in There was only one bulb in the 2 sockets, but light came on, very dim. It would not respond to either switch, and eventually dimmed out. The light bulb works, and the wiring is good. What gives ?
    thanx for any help
    ken
  • lightless Aug 18, 2007
    Just to restate the original problem. The work and night light do not come on. There is ALWAYS 115 volts on the socket. How do the lights get switched on and off? Do the relays supply the ground path? As I stated earlier, after removing and checking both light sockets, one of the lights came on briefly. It was very dim, not controllable with the touch pad switch, and went out shortly. This would indicate that the wiring path is correct, and the bulbs work. The bulbs are a standard replacement from Walmart, I will check and see if some how the rating is wrong.
    I have changed the bulbs after failure without unplugging the microwave, could this have been a cause?
    I removed the control board, the relays are facing each other. What lettering I can see on one of the relays is this
    DUIPU T70
    24 VDC (16)5A
    250V~
    Thanks for any help, hard to troubleshoot by email
    I would black box the control board, but it is ~ $160
  • 944 Answers
Check you are getting 115 V with the bulb in circuit (safest way to test this is to solder a couple of bits of wire to one of the bulbs so you can access the terminals with the bulb inline (be careful), and then measure voltage across it.) The load imposed by the bulb may be causing the power supply to go into a protection mode - usually only if bulb is shorting, but may be a problem with the power relay. If there is a problem with the power supply, through the control board relay or otherwise, this will tell you for sure. Otherwise, if there is definitely the right voltage to a good bulb, then it will light. Check that the bulb is definitely making contact well, and make absolutely sure you have the correct bulbs for 115v, not the 220/240v ones. If this gives you no luck then please ask again with details of what you found. Hope this helps :)
Posted on Aug 16, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Aug 17, 2007
    Only things I can think of are the bulb sockets themselves or the bulb circuit relays. Possibly the sockets are grounding to the chassis?
    As mentioned, if a good, correct lightbulb is getting the correct voltage, it will light unless the load it imposes on the supply circuit causes that voltage to shut off or change.
    Just possible the relays are both damaged (possibly a power surge) but they could conceivably work for a while when cold. If you can get a part number off the relays if you can identify them, i can try and track down details.
    are either or both of the bulbs wired to switch on with the door opening? if so check the door switch - they can often fail - usually corrosion due to over-zealous cleaning or merely overwork.
Bulb replacement
Is it an over-the-range (OTR) microwave or a countertop microwave? If it's an OTR microwave, are you talking about the light(s) on the bottom of the microwave, or the one that lights up the cavity when you open the door or run the microwave?
If it's an OTR microwave, and the cavity light is burned out, you MAY be able to access it by removing the grill vent by removing the 2 to 4 screws above it. Then, depending on the model, either slide the grill vent to the left and pull it out, or else pull out the top part of it first. Then, if there is one, you may see an access cover behind the grill vent. Unplug the microwave, then remove the 2 screw that holds the access cover in place, and lift up and remove the cover. You should now be able to get to the light bulb.
If it's a counter-top microwave, you will have to remove the complete cover by removing the screws on the back, and possibly a couple of the sides. Note, 2 screws are special security screws to prevent the casual customer from fixing his own microwave oven! UNPLUG THE MICROWAVE FIRST, then remove the cover screws. Slide the cover back about 1/2 inch, and then it should come completely off. You should now be able to see the light bulb to change it. Then reverse the process to put the cover back on. I hope this helps.
Oct 21, 2014 | Microwave Ovens
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
I have a sharp r1480 microwave. the work lights do not turn on. the bulbs are good,and light buttons beep but no light.
listen for a click not just a beep, if it doesn't click the relay is bad on the pc board, if it clicks the trace may be blown to the relay
Jan 26, 2010 | Sharp R-1480 Microwave Oven
I have a Sharp model R-1610 Microwave. The work/night light does not work. I"ve changed the bulbs.
Does it operate with a membrane-type touchpad?
These things seem to be problematic as the microwave ages.
They are usually replaceable, and the cost is not great. I just installed a new touchpad on an LG, and it cost $25.00 plus shipping.
Oct 12, 2009 | Sharp R-1610 Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Hood Lights not working
The problem lies in the circuit board / control panel. We regularly repair these control panel assemblies nationwide for 32.50.
Oct 06, 2006 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
188 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
