Question about Alpine CDA-9885 CD Player
Cut out Alpine 9855
Hi, I just installed an Alpine CDA 9855 into my car and works fine, but after a few minutos, less than 3, into CD mode, the radio turn off. A few seconds later turns on again. Seems the thermal proteccion was activated in some way but I don't understand why. I connected the blue/white wire to the amp power so that would not be the problem... Any ideas? regards
  • Chrispy1 May 21, 2008
    My alpine 9885 shuts itself off and comes back on a few seconds later at what seems to be random times. I am running after-market amps, subs, and speakers. I am not running anything stock. I have the internal amp in the head unit turned off, and have also hooked the power and ground directly to the battery and it still shuts down and comes back on randomly.
    Any help is appreciated.
Get a capacitor if u are running subs and aftermarket amps. problem solved.
Posted on Jul 16, 2008
    Problem Solver:
  • 10 Answers
When you say you connected the blue and white wire to the amp power do you mean the remote turn on of the amp and not the terminal/wire marked battery or power? You should not be trying to power your amp with the blue and white wire. This wire is only for sending a signal(+12V) to the amp to turn itself on. the amp should have it own fused wire of appropriate gauge running directly to the batttery. Some more details on the installation would be helpful.
Posted on Aug 15, 2007
Alpine CDA-9885 has no sound to rear speakers when playing a CD. Works OK when in tuner mode?? What up??
Are you running your rear speaker through an amplifier? If so, you are probably using the blue wire (power antenna remote turn on) instead of the blue/white wire (amp remote turn on). The blue wire turns off when leaving tuner mode, thus turning off the amplifier.
Jul 10, 2012 | Alpine CDA-9855 CD Player
I have a CDA-9855 Alpine head unit. It worked just fine when removed from my prior vehicle (05 VW Golf). I just installed it in an 01 Land Rover Discovery II using a wiring harness adapter so no cutting or...
it sounds like you have the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) turning on an external amplifier in your rover. the antenna remote wire turns off when you leave tuner mode.
Jan 26, 2011 | Alpine CDA-9855 CD Player
THE STEREO CODE FOR ASN ALPINE CDA 9855? HOW OR WHERE DO i GET IT??
there is no code for an alpine cda 9885. what seems to be the problem with the radio?
Jan 03, 2011 | Alpine CDA-9885 CD Player
How do you set the radio stations on a alpine CDa-9855
go to a station you wish to save, then choose a preset number from 1 to 6. press that button for 3 to 5 seconds. the station should be locked into that preset number.
Dec 13, 2010 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Change illumination colour Alpine CDA 9853
1. Go to menu
2. Using touchbar go to 2nd function
3. Using touchbar choose a preset colour or tap P1 at the end on the touchbar and use the volume round thingy to choose your own colour by turning the volume knob.
Jul 10, 2009 | Alpine CDA-9855 CD Player
Alpine CDA 9855 plug configuration
an alpine dealer will have the ability to order a new harness for it.
there is only one made for that particular unit.
May 26, 2009 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Blown Speaker Channels
Chips fail, even for the best of us! If the preamp outputs are still fine, you can purchase a small 4 channel from Alpine for 100-150. About the same as a repair yet cleaner power. Check EBAY there's always good deals to be had!
Hope this helps
May 22, 2009 | Alpine CDA-9855 CD Player
No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Dec 12, 2008 | Alpine CDA-9855 CD Player
Music Won't Play
ok I had this happen before
Try unplugging the possitvive battery from your car let sit for 5min or open the doors and turn the key making sure that your car is completly dead. then put the possitive wire back on.
this will reset the deck and make sure you also have the setting s correct I thin it called I tunes is set to on in the menu opptions
May 01, 2007 | Alpine CDA-9855 CD Player
Alpine CDA-9885 CD Player Logo
229 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
