Question about Sharp AL 1631 Copier
Sharp AL-1631 copies very light at top only
My Sharp AL-1631 copies are very light at the top 1/4 of the page only. I had Sharp on the phone and after a bit of troubleshooting, he said I would have to send the unit in for service. We can live without the copier, but working a large company, I know it will be quite a hassle to get my purchasing dept, shipping dept, etc involved. Do you have any sugesstions? I'm not opposed to taking the machine apart a bit to get to the bottom of this. Just as a side note: 99% of our copies are onto Avery labels that are fed manually. Thanks!
  • amyobrien Aug 30, 2007
    The machine is reading 2746 copies. I'm not sure what you mean by the fuser sticking. When the warming up, it produces a rough clicking noise. Users have mentioned before that many times it would jam on the first copy then be OK. I have just replaced both the toner and drum to see if that would help. I was sure to use genuine Sharp products as mentioned earlier. Is there anything else I can do?
  • 32 Answers
How many copies on tha machine? Hold the clear button down for 10 seconds and watch the counter led. Most of these I work on have problems with the fuser sticking. Does it sometimes click then jam? Also, if you are filling your own cartridge be sure to order developer along with your toner.
Posted on Aug 27, 2007
  • Anonymous Sep 02, 2007
    If when the machine clicks and causes a jam, take the paper tray out and you will notice that the feed tires are not in their home position then I would look at cleaning the clutch on the end of the paper feed assembly shaft. It can be removed without pulling covers by taking the E clip off the end and carefully working the shaft out. I clean these clutches with acohol and then lube them with a light grease. Vasoline will work but silicone is better. The sticking fuser I was taking about, I have seen the "Bearings" on the ends of the upper fuser roller "The hard one" get so gunked up with paper yuck & Toner that it causes the fuser rollers to drag and the drive mechanism in that copier is not strong enough to keep from slipping a gear. If this machine is under warranty or you can get it fixed by Sharp for under $150.00 send it in.
  • 328 Answers
Main thing is to absolutely use genuine Sharp toner and drum supplies. After that,probably lamp is not responding are activating quickly enough. Caused by main board or high voltage power supply.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 15, 2007
6ya staff
SOURCE:
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Sharp Al 1631 prints half a page
Sometimes the originals hesitate using the document feeder, which can cause the problem you are describing. Do you get the same rsults if you lay the original on the glass?
Apr 29, 2009 | Sharp AL 1631 Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
Al 1631
Simple you get a PM, new developer.. call an authorized Sharp Tech...
Oct 21, 2008 | Sharp AL 1631 Copier
Sharp AL-1631 - would not copy.
Your unit definetly needs a new drum. The usual yield for this consumable is upt ot 15,000 pages, so at the stated rate, the unit yielded more than average. AL-1000 series share the same toner and drum, so finding remanufactured (or recycled) drum units should be no problem. In Puerto Rico, they are sold for about $79.00.
Oct 05, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
227 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
