Question about Toshiba Libretto 100CT (P000249540) Motherboard
How to overcome 8.4gb bios limit on a toshiba libretto 100ct?
I have a toshiba libretto 100ct and I have a 80gb toshiba hard drive that I want to install on to it. What do you think I should do? I have herd of drive overlay programs but I do not know how to use them. Also could I partition it in to 10 8gb partitions. If possible How would I do this? What is recomended? Regards, biltho
  • Anonymous May 07, 2009
    hey guys, i would really like help on a related problem... I want to install linux (a small distribution) on my toshiba 100ct, it has a 1.9 GB hard drive, no usb ports, only pcmcia ports, and usb pcmcia adapters don't work with it... so I can only transfer files via a compact flash (cf) card attached to a pcmica adapter, but even if I get the linux distribution on there I can`t boot form the cf card, I was hoping someone could help
I have a solution, its sort of BIOS fix.
I've found it on the net a while ago, but can't find the URL now.
I can email you the procedure and all relevant files and info.
I've did it for 20G HD, so I assume no reason why it shouldn’t work
for larger one as well.
Post you email if interested.
Handyman
Posted on May 01, 2008
By taking out the HDD and format FAT32 by using external usb on other pc. Don't forget to copy WIN9X CD into the HDD. Put it back on the laptop and boot from floppy. Run windows installation.
Posted on Mar 04, 2008
That is not a solution. The BIOS doesn't gauge the size of the disk by the partitioning, it's from the cylinders, heads and sectors.
Posted on Dec 31, 2007
  • Toshiba Master
  • 12,061 Answers
Ok get a program called Partition Magic, I have found you a Tutorial here: http://www.le.ac.uk/cc/dsss/docs/pm4-main.shtml Basically, you divide the 8.5GB into smaller sizes, NO MORE than 4GB, so say 2x3GB, & 1x2.5GB, or whatever suits.. then ya Format each Partition, Make ONE an Active Boot Partition, the rest logical ones. Your actual Size of the drives will be less than the Total due to Formatting information etc. Read the tutorial carefully B4 ya do anything. Ya be using the bigger storage in no time...
Posted on Aug 15, 2007
SOURCE:
Toshiba satellite m40
The model Toshiba laptop came installed with a 80Gb hard drive and can support a hard drive up to a max. 120Gb.
If you want a larger hard drive you will need to use an external USB hard drive.
May 06, 2013 | Computers & Internet
What are the maximum limit to increase the hd,ram,prossesor in sattelite u100 toshiba notebook 2005
Your model has room for one expansion memory module. Toshiba typically came configured with one static module. The memory specification is very likely DDR PC2700. The maximum size available for one memory module of DDR PC2700 is 1 GB. The HD size is only limited by what you can find with a PATA (IDE) interface, typically 320 GB. Installing a new processor may be prohibitively expensive, and the speed would depend on BIOS support. The BIOS may support the fastest Pentium IV processor, @ 3 GHz.
A link for a 320 GB drive, @ $96.28 (shipped) is here.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136345
The link to your manual is:
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=http--cdgenp01csdtoshibacom-content-support-manualserguides-su1036115-librettou100-u105ug20050511pdf&sliceId=pdfPage_1&dialogID=117884287&stateId=1%200%20117882861
If you find this helpful, please vote accordingly. I'm just getting started helping here and the votes would be great thanks :)
Aug 11, 2010 | Toshiba PA2502U - Libretto 100, 110,...
Need to boot into BIOS to change IDE setting. No Floppy drive.
hi
To enter the BIOS during start-up press the ESC-key while switching power on
hope this helps :0)
May 19, 2009 | Toshiba Libretto 50CT Notebook
Toshiba libretto BIOS Reset
If there is a password that is not allowing you to reset the BIOS, I would recommend going to the following website and having one of the technicians use their proprietary devices that can unlock it for you. Im not sure if there is a charge but this may be the best solution to avoid any headaches. Just let them know there is a bios password preventing you from entering the BIOS and you need it removed and they should be able to help you from there.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/gaspLocator.jsp?subs=tais
Mar 06, 2009 | Toshiba Libretto 100CT Notebook
I cant reformat my Toshiba libretto L3. I tried everything
You cant boot from cd. Try changing the boot order in the BIOS and allow the CD to have ownership over the Harddisk Drive. This way the computer is forced to boot from the CD.
Jan 16, 2009 | Toshiba PA2502U - Libretto 100, 110,...
Defecttive hard drive
I have a Toshiba Satellite M45 S 169 that crashed. I think it is the hard drive because that is where the noise was coming from. The part is an Hitachi Travelstar Model:HTs541080G9AT00 and it is hdd-80gb. Where can I find this part and how can I just insert a new hard drive easily?
Jul 07, 2008 | Computers & Internet
LCD vertical lines
hi, all the LCD cable contact pins to be cleaned, if still invain then u will need to replace the LCD..
Mar 16, 2008 | Toshiba Libretto 100CT Notebook
Libretto 100ct
Está desliogando sozinho.... o que fazer?
Oct 25, 2007 | Toshiba PA2502U - Libretto 100, 110,...
100Ct
Hi, Depends on what OS you are using. For this particular model (Libretto 100CT), it is probably either Win9X or RedHat (or some Linux variation). In Win9X, you might try F8 & run it in DOS and run: Scandisk c: /autofix /surface; Scanreg /fix If it is beyond repair you have to have access to the OS installer CD. Sometimes Win9X installer is also saved in the HD. Try checking if it is inside your HD and run setup. Hope this be of some help. Pls post again how things turn up. kind regards.
Jul 24, 2007 | Toshiba Libretto 100CT Notebook
Toshiba Libretto 100CT (P000249540) Motherboard Logo
659 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
