Question about Garmin StreetPilot i5 GPS Receiver
My garmin i5 doesn't know where it is +
Hi, My garmin street pilot i5, which is still under warranty, has several problems. 1. last time I took it out, it didn't know its location; it was at least 3 miles off course 2. the audible instructions are erratic: sometimes there are on, sometimes there are off 3. several times garmin couldn't recalculate the route because its memory didn't allow it to do so. Should I return Garmin? Is it beyond repair? Please help. Thank you. Mazemule.
  • 1 more comment
  • gvy2000 Dec 27, 2007
    I'm having same problem with my i5. I've been using it fine for almost 2 years until almost a month ago, it started having a problem locating satellites. It seems to forget it's location once you turn it off.
    What I've observed is after some effort locating, it will ask you:
    1) Are you indoors? I will reply NO
    2) Did you move hundreds of miles since last used? I will reply NO
    3) Is today - I will say YES, because it's correct date.
    It will continue searching unsuccessfully. What I'll do is I will turn it off and go to recent searches and select the same location I was going to. After approximately 5 mins, it will find it's location and I can finally use it. But if I turn the unit off, I will have to go through the same thing all over again! Does anybody have a better solution?
    Gio
  • R MOORE Jun 26, 2008
    My Street Pilot i5 can not locate satellites. Worked fine last week in Boston but not now in San Diego. New batteries. Fresh download of software. 2 hours under a clear shot to the sky where it has always worked before. Also will not reset when Left arrow, wheel and power button are pressed.
  • ricarde Jul 13, 2008
    Exact same problem as described, also in Boston. The power reset didn't work. Garmin sent me a new, i.e., refurbished, unit, under my warranty, and the new unit (received this week) does the asme thing. It thinks it is in Iowa searching for the field of dreams, the time settings are not even close, and its asks me the same questions (where are you? etc.) that the other osters have reported. I think there is a defect in the i5 that for some reason Garmin won't acknowledge.
"Best solution" dated 2/27/08 worked for me, so I have to amend my posting of earlier today. The master reset process didn't help by itself, but when I took the i5 out into an open area (after using master reset), it located where it was and set the time. Great solution. Thanks. Too bad I had to go through about 10 emails with Garmin first. Thanks. Ricarde.
Posted on Jul 13, 2008
Garmin tech support suggests a master reset as the solution to your problem. To do this (1) power off the unit; (2) hold down back arrow and scroll wheel and at the same time press the power button: (3) when asked if you want to erase all user data, select Yes; (4) when this is done turn the power off and take the unit outside where you can see the entire sky; turn on the unit on and with it horizontal to the horizon wait from 10 to 40 minutes for it to acquire satellites (closer to 10 than 40). Your unit when turned back on should acquire satellites faster and not lose them like you do now, but you will have to reinstall your Go Home location and probably any custom POI's. Hope this works; it did for me. The problem it corrects is possibly when you initially turned it on you didn't have a clear view of all the sky and you only downloaded some but not all the satellites overhead. When the unit is in use and tracking routes it needs to access more than one satellite to exercise all its functions.
Posted on Feb 27, 2008
I would suggest that you return it to Garmin since it's still under warranty. My Garmin i5 will NOT operate on just batteries. This unit is also under warranty. Also, the suction cup mount fails to hold onto the windshield. I've been concerned about how many people seem to have problems with these units.
Posted on Sep 06, 2007
Garmin Street Pilot c330
Pull the face off try to reset it, if it will not reset, or work in the car or the house, the battery needs swapping out,
Garmin $100
Regards
Jun 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen screen on ''aquiring satelite''
Try resetting the I5. Hold the left button, the wheel button and the power button down at the same time. Keep holding until the screen say that " Do you really want to erase all user data?" Select Yes and then restart the I5.
Nov 11, 2008 | Garmin StreetPilot C330 GPS Receiver
No voice audible
Garmin Street pilot i5 lost voice. Any suggesstions
Jul 29, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin i5 street pilot
I had an i5 that lost voice. I fixed it by just replacing the speaker. Take it apart and measure the resistance on the speaker. If it is open or not 8 ohms, then you can use this speaker.
http://mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMuNFJjvCI6tQmnbmXzUsCMVOlE6Umf83Zs%3d
Good Luck
Jun 09, 2008 | Garmin StreetPilot i5 GPS Receiver
Gps - street pilot i5 garmin
try this first-if the unit has batteries installed, remove them so unit runs on power cord only
Jun 01, 2008 | Garmin StreetPilot i5 GPS Receiver
Garmin street pilot c330 - Suction cup lever broken
If you cannot un-assemble the suction cup assembly to fix it, then you would have to replace it. If it is under warranty, demand an exchange.
Jerry G.
Jun 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c510 problems
Have you tried charging with your computer? Sometimes this can help.
Mar 03, 2008 | GPS
Garmin Street Pilot i5 Stopped working all of a sudden
Resetting Your StreetPilot
If your StreetPilot freezes (stops responding to button presses), try turning it off and then on again. If this does not help, remove the batteries and then reinsert them. Disconnect from external power, if necessary.
Clearing all User Data
If resetting does not fix your problem, you may need to clear all user data from your StreetPilot.
• IMPORTANT: zf you clear all user data, you will delete all saved locations from My Favorites I and all settings in your StreetPilot. Be sure you want to clear all user data before proceeding.
To clear all user data, press and hold down all buttons in the following order: ciJ, Wheel, Power.
Continue holding down all buttons until you see a prompt, “Do you really want to erase all user data?”
Select
Yes.
Nov 16, 2007 | Garmin StreetPilot i5 GPS Receiver
Garmin StreetPilot i5 GPS Receiver Logo
280 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
