Question about Sony XM-2150GSX Car Audio Amplifier
Wiring Diagram for Sony car amplifier XM-554ZR
Hi, I bought a Sony car amplifier XM-554ZR 4 chanel. 2 for front speakers & 2 for back speakers. how i will connect my Subwoofer in this amplifier. Can any one send me a wiring diagram?
  • sunny_Blr Aug 14, 2007
    Thank You very much. But my problem is I have 5 Speakers (2Nos Pioneer 4way speakers in the front, 2 Nos Pioneer 5way speakers in the back and 1 No 10" RCA subwoofer with enclosure) all together 5 speakers. But my amp have only 4 outputs. Can i connect all 5 speakers to apm?
    President:
  • 1,114 Answers
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 14, 2007
  • Greg Cann
    Greg Cann Aug 14, 2007
    The short answer is no!
    Your options are as per the diagrams:
    1. 4 full range speakers with filters off.
    2. 2 full range & one sub with filter on.
    3. 2 full range & 2 subs with filter on.
    Because you need the filter switched in to feed sub(s) it cannot connect rear sub(s) & full range speakers at the same time.
    Sorry but this amp does not suit your needs if you want all 5 speakers you have connected.
This amp is fine to push 5 speakers. it is 2 ohm stable in stereo. what you need to do is connect the left front and rear speakers to the left front out, and both right speakers to the right. this will make a 2 ohm load. you will lose front to back fade but still have left/right fade. if you only have 1 sub , bridge the rear channel to run it. this will make a 4 ohm load and your amp will perform great.
Posted on Jun 07, 2008
  • 26 Answers
HI DUDE its simple ... your front ch u plug 4 speaker means left 2 speaker right 2 speaker ... for ur sub use rear ch bridge mode left positeve and right negative ur amp shows this + - + -
Posted on Jun 04, 2009
Hi anyone help me i hav 2 front tweeter and 2 rear pioneer speaker . 12 sony woofer with 2 channel jbl amp.. plz tell me how to connect
Posted on May 25, 2011
1 preamp output on stereo but want 2 amps
Posted on Apr 25, 2008
SOURCE:
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
My xr-m550 stereo didnt come with wiring labels
well the most common wire for the new stereo is black (earth), red(Power), blue(Remote), yellow(memory), white,grey(front speakers), green, purple(rear speaker) lil hint if u havent taken the stereo out yet when u do transfur every wire 1 by 1 then u no u wont stuff up
Oct 22, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Wont stop going in to power protect mode
Hi, does it still do it with speaker disconected?
Aug 04, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
How to put 2 subs on a Sony XM 554ZR bridged
Unless it is a 4 channel then you will have to run them in series. Keep in mind that you will only have mono sound.
Jul 07, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
I have a Xplod XM-554ZR Car Amp and the green light is blinking it worked just befor and now i have no sound
The amp is in protection. Disconnect any speaker from it, then turn it back on, if it's not flashing, check your speakers with a meter and check speaker wires for shorts. If it's still flashing, you've blown the protection circuit and it needs to be replaced or repaired. Hope this helps
Jun 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod xm-554zr amp
try disconecting ur battary for 2 min and try it again
Jan 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Car amps
important is to hav correct wires and groud cable...
Dec 29, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
if you are trying to run some highs with built in high-pass crossovers off of a amp that is setup for subs(amp is on low-pass) then your highs will not work. You are better off running another amp or running them off of your deck...
Aug 18, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony XM-2150GSX Car Audio Amplifier Logo
19,765 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
