Question about iLO MP3 Player
My ilo mp3 of 1 gb
Ok i jus bought my ilo mp3 3 dayz ago it costd me 38 sumting and i coneccted it 2 my usb and labtop n it has a sd card slot on the mp3 player do i need 1??? i need musik wen i git on the bus 4 school and i dont know how you transfer the music i already have the music i want on it its on my windows media player PLEASE HELP????
    Problem Solver:
  • 11 Answers
No you don't need the SD, its just extra :) let your computer boot up, plug in the USB cord, and you should hear that famous little "bo-dunk!" sound that tells you something just got plugged in and windows freakin' found it. then a screen may or may not come up asking you what you want to do. if so, its pretty self explanatory from there. if you don't want to use whatever it asks for, go to WMP and go to Sync. Add your songs to the list by copy and paste, and it should say its adding the files to the device. also, if you watch the screen of the mp3 player, you'll see it flash "USB Transferring", showing that its gobbling up the songs you're feeding it (in a good sense) lol. After all the songs are copied, boot up the player (you might have to unplug it first) and make sure they work. Sometimes they freeze, sometimes they dont. For me, when they freeze i just get rid of em. I don't know how to fix the freezing, i guess its just a mishap of technology...they're everywhere. Anyways, try this and let me know what happens. hope this helps :)
Posted on Aug 21, 2007
SOURCE:
I just bought sd card for my ilo but when I try to access it wont let me store any music. How do I format it and prep it for access?
You need to format all new cards. Does your Mp3 player show up as a drive when you hook it up to your computer if so open that drive right click on format use FAT32 for windows os. If your Mp3 player does not show up as a drive use the SD slot on your computer to format. Choose the SD card slot drive right click on the drive choose farmat... use FAT32 for windows os. and you should be off and downloading great tunes... Good luck hope that helped.
Oct 06, 2009 | iLO (2 GB) MP3 Player
I need help uploading my SanDisk SDHC 4GB Memory card to my labtop throgh the SD slot in my labtop
SD and SDHC are NOT the same. go to radio shack and get a usb micro sd card reader and transfer that way but again SD (2<GB) and SDHC (2>GB) are not backward compatible .
Jul 11, 2008 | Cameras
Jensen vm9511ts
Remove the unit and bench test it. Sound like you have a loose power wire. Goodluck.
Apr 16, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Adding a 1gb memory disk
open the battery door and insert the sd card into the slot provided
Dec 29, 2007 | iLO (2 GB) MP3 Player
I bougth a 4GB SDHC card for my 1 GB ilo w/expansion slot, will it work
my new ilo 1gb mp3 player's manual reads: you can use up to a 1 gb sd or mmc card. hope this helps. :)
Nov 30, 2007 | iLO MP3 Player
Ilo mp3 player s/n 0770100321415 1gb with sd card slot
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Sep 12, 2007 | iLO (2 GB) MP3 Player
Adding SD card to my ILO
What, you actually hotwired a flash card into the Ilo? Impressive. Or are you trying to get the Ilo to play music from an SD card, when you have both plugged into the computer? If you're talking about the first, then I'd say you did a good job at NOT destroying your Ilo. If its the second, then unplug your Ilo, put your headphones into the headphones jack in the computer, and play the music from your computer.
Aug 22, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player
For my Ilo I can see the Ilo just like another drive when it is connected to the USB port. I can move files to/from the ILO just like any other drive. Similarly I can delete the files just like any other drive (for example using Windows Explorer).
Aug 08, 2007 | iLO (2 GB) MP3 Player
Memory expansion slot
If the SD card is a compatible type, it should just read it
May 10, 2007 | iLO (2 GB) MP3 Player
54 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
