Question about Sony Cyber-Shot DSC-T1 Digital Camera
Power cycling My T1 sarted turning itself off and on while in the cradle. I was downloading pics to my PC. Power to the cradle is not connected. Only the USB cable. Also, it appears that openning or closing the lens cover is not always turning the camera on and off as it should. Power shows 45 min left. I have removed the battery and it looks OK. Contacts appear clean.
    Genius:
  • 2,985 Answers
This seems to be a circuit fault check the manual[Full manual on the software CD in PDF] And look for any fault indicators. If no sign then the manufacturers Support If it is 'young camera' it may be replaced. But a 'Repair' will be pricey
Posted on Aug 16, 2007
SOURCE:
My pocket pc e310 wont turn on. i only have the cradle and no ac charger. i have unplugged the battery for a reset but nothing happens after i plug it back in. when plugged in to the cradle, there are no...
The e310 can't use USB power to charge through the cradle. (It needs more than USB specs allow.) You have to supply +5v DC to the connector at the cradle or the e310 itself. Positive terminal is the center pin/hole, negative terminal is the outside barrel of the plug.
Jun 02, 2011 | Toshiba e310 Pocket PC
On start up it is say sart windows normailly all
Try to turn off the laptop, remove the cables and battery. Then press and hold the power button for 8 secs. Reinsert the cables and battery on the pc. Turn on the pc and hopefully that prompt will not occur again....
Jul 26, 2010 | Acer Aspire One AOA110-1588 Notebook
I get a black screen when I turn the camera on to take a pic or video. It will take a pic, but it's black.
Its known problem of ccd imager chip failure in Sony DSC-T1 camera and Sony offers free of cost ccd imager chip replacement.
Click Sony CCD Imager Support for details.
Thanks.
Dec 28, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
View finder cant pick up picture
It is ccd imager problem that will be replaced for to view live to take pictures.
Sony will repair free of cost DSC-T1 for bad ccd imager problem as per announced scheme. Only $20 will be charged as shipping charges.
Click Sony CCD Support for details.
Apr 08, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
My charger doesn't seem to be charging the cyber-shot.
If its DSC-T1, Sony cybershot, you can download pictures in to PC, from memory stick by using compatible Card-Reader.
I cant understand CAF...sorry.
Aug 05, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help
There seems to be a problem with the cradle not "lifting" itself up and over what appears to be some sort of guide. Rock the cradle gently back by hand (it will only move a few millimeters) and move it all the way to the right into its bay. Cycle the printer power and it should be fine.
Mar 03, 2008 | HP PhotoSmart 7260 InkJet Printer
Focusing
This is ether focusing motor itself or CCD sensor is starting to malfunction. In either case it should go to a repair outfit. If I am right and it is a CCD sensor you can have it repaired ( sensor module replaced see enclosed pic ) FREE OF CHARGE BY SONY.7761b2a.jpg
Jan 02, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Can't download pics
Dear daj43
I think u have not installed the software for it on ur pc, incase u have installed the software and still it persists, try to notice if the software is loaded and running when connecting the camera. I would always suggest u to remove the memory card and use it in a memory card reader/writer to transfer the images to pc.
Dec 24, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Why does my axim power on by itself?
I've noticed that mine will power itself on as well. But is usually goes like this... 1. Sync with computer 2. Unplug cable 3. Turn off Axim 4. ~1min later...Axim is on and at the password screen
Sep 14, 2005 | Dell Axim X5 Pocket PC
Sony Cyber-Shot DSC-T1 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
