Question about Sony KV-32S25 32" TV
TV JUST SHUT OFF
I WAS LOOKING AT TV AND IT TURNED OFF AND WON'T TURN BACK ON. OUTLET HAS POWER BUT TV HAS NO SINN OF POWER , SOUND OR PICTURE.
    Problem Solver:
  • 18 Answers
Ok your going to need a VOM meter and a soldering iron (25 to 53 watt, not a soldering gun). By no sign of power Im guessing that there is no click or any kind of "electronic" noise from inside the set. Ok, safety first, unplug the set and once you open it stay away from the high voltage anode wire that goes to the CRT (picture tube). In side by the power supply locate a resistor that should be at location R607, it is colored white and has a value of 0.1 ohm. It is most likely open, if so then most likely Q601 and Q602 are shorted as well, you will have to replace them and it is very important to also replace the following (shorted or not) R644 6.8ohm I think 1/4 watt and VDR601 VDR602 and VDR603 One of them is color black and the other two are green. I think VDR601 is the black one but dont quoat me on that. Next go to the Flyback transformer largest transformer in there (roundish in shape) near it is the Horz out transister I think it is location Q591, check with your VOM to see if it is shorted, if so replace it. Once you have that done solder the pins on the flyback and the Horz drive transformer, again dont quoat me but I think it is location T503. If you have a ESR meter check the electrolytic capcapscitors. Hope this helps! Good luck! Don
Posted on Aug 14, 2007
Blue light but tv won t turn on
Try these troubleshooting steps:
- Try to power on the TV using the button on the TV and not the remote
- Ensure that the power cover is securely connected
- If you are using a power strip connect the TV directly to the wall
- Try a different outlet
- Can the outlet power any other device?
Good luck
Feb 05, 2014 | Sceptre Televison & Video
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
TV turned off by itself and now it won't turn back on
If the tv has nothing happening at all when you try and turn it back on including any noise, your power supply is broken. If it is still trying to turn on or does make noise, an internal component has come loose or been knocked off, most likely to your picture tube.
Dec 25, 2008 | Televison & Video
No Picture - Sound
I just had this problem fixed. In my case, it was because the insulation on the CRTs was cracked, and when it would warm up, the shielding would separate and would let 5000 volts arc across the main board. This, obviously, damaged the board. The tech didn't catch the arcing right away, so they replaced the main board twice before they used a high-temp RTV to patch the insulation.
The power-cycling was a result of the damaged board.
The point of this story is that the broken part may be a symptom of the real problem.
I hope this helps someone!
May 29, 2008 | Samsung HCN653W 65" Rear Projection...
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Televison & Video Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
