Question about SanDisk Sansa e260 MP3 Player
I got a used sansa e260 mp3 and my computer won't accept it?
Yeah, my boyfriend gave me his and it worked perfectly on his computer. I have it now...and the cd. I installed the media converter so i'm guessing that's the only software i got to download from the cd. the problem when the mp3 is connected to my computer, it won't appear in the "my computer" file, so i can delete songs or videos, etc. You know the "Found New Hardware Wizard"? it comes out everytime i connect the device, so i know i got to install it but when i'm going through the process, an error appears saying that "This Device Cannot Start." I've checked everything, and it's alright, but i still don't know what the problem is.
My computer program is "Windows XP"
and it can access the mp3 by using mtp mode (only).
thanks
please help
    President:
  • SanDisk Expert
  • 652 Answers
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier
Posted on Mar 24, 2009
SOURCE:
mixmaster
  • 626 Answers
SOURCE: Sansa e260 won't accept pictures
Are you using the Sansa Media Converter to convert / transfer the photos?
Thats the only way to get photos / videos on the Sansa Products.
The Sansa Media Converter is here if you need it;
http://www.sandiskthailand.com/images/SansaMediaConverter.zip
Best of Luck.
Posted on Oct 25, 2007
  • 5 Answers
SOURCE: Computer will not regognize Sansa e260 at all
Maybe the problem is not the player or what you are downloading but the program you are using to get the music on your player. I had a similar problem and I just had to use a different program to load my music.
Posted on Jan 02, 2008
SOURCE: Why does this happen to my converter/e260? (pic)
the sansa media converter is only used for videos and pictures.
for song you go to my computer and u will see that it says sansa e260 you click on it then it will have files for music vieos pictures and recoding click on music and drag ur music on to it.
Posted on Jan 17, 2008
SOURCE: sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Posted on Oct 03, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa e260 will not connect to computer
Unplug the Sansa from the computer. Turn it off. Hold in the REC button. Reconnect the Sansa to the computer while holding in the REC button. After 10-15 seconds of continuing to hold in the REC button, a window should pop up saying "Found New Hardware Wizard." Complete the Wizard.
-Tha Mp3 Doctor
Posted on Dec 29, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Sansa e260 wont be detected by computer
I assume that you are running an older version of Windows from XP/2000. If you can get on the internet, go to Sansa's site and download the driver from there. Here is a link http://mp3support.sandisk.com/sansa/SMC
May 30, 2009 | SanDisk Sansa e250 MP3 Player
My mp3 player won't recognize the memory card.
First, make sure it's a microSD card; the e260 won't work with microSDHC cards.
Then use a card reader to copy music tracks to a "MUSIC" folder on the card. Install the card into the e260 and you will see the additional music.
Mar 08, 2009 | SanDisk Sansa e250 MP3 Player
Rhapsody not recognizing my Sansa e260
Get the Vista-compatible software from Sandisk's website
Jul 24, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
The e260 works with microSD cards. Your 4GB card is actually a microSDHC card and won't work in the Sansa.
With a microSD card, simply put music tracks into a folder called "MUSIC". When the card is installed, the Sansa will see the additional tracks.
Jul 14, 2008 | SanDisk Sansa e260 MP3 Player
Royally screwed up e260
help! i have tried to download my copied cds through rhapsody & windows media player. nothing happens in rhapsody & windows gives me an error occurred message after each song when i try to copy to e260.
thanks for your input,
trish127
Mar 21, 2008 | SanDisk Sansa e260 MP3 Player
I cannot get photos to copy over the the photo folder on my sandisk anyone know how to do it?
yeah connect your sansa into computer using the usb cabel
install the software you got with your sansa and convert your pics in the sansa converter it should get the photos into it if it´s connected auto
Feb 14, 2008 | SanDisk Sansa e260 MP3 Player
Problems with Sansa
I use windows media player and it works very well. I am not sure if that is the same thing as windows xp but it is worth a try.
Jan 04, 2008 | SanDisk Sansa e260 MP3 Player
Best of Luck.
Oct 25, 2007 | SanDisk Sansa e260 MP3 Player
Waterlogged sansa mp3!!!!!!!!!
Water damage not fixable - replace
Feb 12, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
169 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
