Question about Canon PowerShot A300 Digital Camera
A300 e24 error code and buzzing sound
I opened the lens of my canon a300 and a buzzing sound was heard and then the lcd read error code 24, what could it be and how can i repair it as its out of warranty, and to expensive to get mended.
  • david lewis
    david lewis Dec 17, 2007
    i fixed it in the end by pressing shutter button and power on button same time corrected the problem
    Genius:
  • 2,985 Answers
This seems like to lens extending motor has gone. If it is out of warranty and the cost of a repair is expensive as you have discovered You will have great fun taking it to bits But you will not be able to repair it. So -new camera- eventually
Posted on Aug 16, 2007
  • john ash
    john ash Aug 16, 2007
    This link may point to a manual
    http://pagead2.googlesyndication.com/pag...
    but parts are another story
SOURCE:
E24
Canon E24 error means that there is a loose connection inside the camera, or even a broken (cracked) flexible pcb.
Open the camera up and check all pcb connections, especially to the LCD and to the lens assembly. With the camera open, power it up and wiggle each connector in turn to see the effect, but make absolutely sure not to touch any of the flash circuitry as it can give you a shock and a burn (absolutely do not do this at all if you have a pacemaker fitted). You'll need to have a set of jewellers' screwdrivers and an anti-static wrist strap (properly earthed) whilst doing this. If I've lost you already, then it's not a DIY repair.
I cannot be more specific as you spent no time at all to provide exact model details, nor even a proper question, sorry.
Feb 26, 2011 | Canon Ixus30 Ixus40 Ixus 50
When turing on my Canon SX100IS camera it opens the lense then closes and gives me an E24 error. I am able to replay phones on my SD Card but not take new pictures since the lense retracts
you get this error message E24 because your lens is slightly out of alignment. Cycling the camera on/off several times will serve to help the lens to work it's way back in alignment.
Even though your battery may be fully charged, as a Lithium Ion battery ages, it begins to lose capacity so you don't have enough power to take any still . Try a different battery.
Clean the battery contacts with a pencil eraser. Sometimes, a dirty battery contact can prevent the battery from providing all the current the camera needs.
Hope this helps.
Jan 24, 2010 | Canon PowerShot SX100 IS Digital Camera
Canon camera when turned on, lens will not
Hi
What you are seeing is a generic error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Apr 04, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Big problem with a95
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
May 26, 2008 | Canon PowerShot A95 Digital Camera
Help Canon powershot A300
I would rather to suggestion you to bring that to canon repair shop sound your lcd having problem.
Please follow my advice and rate me SOLVED
Nov 21, 2007 | Canon PowerShot A300 Digital Camera
When I open the lens... A menu page comes up...
If you're seeing black or distorted images both on the LCD and on the recorded pictures, then this might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info: http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Oct 21, 2007 | Canon PowerShot A300 Digital Camera
Error code
I found the answer on another site and was able to fix my camera myself. E24 means your LCD display has come unplugged. What happens if you rotate the screen too much you tighten up the wire and it pulls the connection out of its socket. There ar 4 screws on hedispla, unscrew ad take th back off the screen. Unwind the screen until the wires loosen up. Replug in the loose connector. Resecure the back
Oct 21, 2007 | Canon PowerShot G1 Digital Camera
Can't take pictures
Defective mechanism,  a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Oct 10, 2007 | Canon PowerShot S200 / IXUS 178 Digital...
Canon PowerShot A300 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
