Question about AT&T 1480 Phone
Date/time stamp on answering machine
I have a corded AT&T 1480 telephone. It is not recording the correct date and time that I am receiving messages
  • Anonymous Mar 20, 2014
    The handset shows the correct time and date. How do I set the time and date on the answering machine part?
Set the correct date and time by pressing "time/set." Then, follow the voice prompts. Press "time/set" again. Use "change" button to advance day. Press "time/set" again to adjust hour. Use "change" button to advance hour. Press "Time/set" again to adjust minutes. Press "change" button to advance the minutes. Press "time/set" when finished.
Posted on Sep 22, 2007
SOURCE:
How do I retrieve recorded messages from an outside phone?
You can access the answering system remotely by dialing your home telephone number from any touch-tone telephone. To remotely access the answering system
Dial your telephone number from any touch-tone telephone. When the answering system answers, enter the two-digit remote access code (19, unless you have changed it). The answering system automatically announces the number of messages (new or old) if there are any. If there are new messages, the answering system automatically begins to play new messages only. -OR If there are no new messages, the answering system automatically begins to play all old messages. You can also enter the remote commands: Play all messages
1 Press to listen to all messages. If there are new messages, the system plays back only the new messages (oldest first). If there are no new messages, the system plays back all old messages (oldest first). Play new messages
2 Press to listen to new messages only. Delete a message 3 Press during message playback to delete the current message. Delete all old messages
3 Press to delete all old messages. Replay current message or previous message
4 To repeat the message currently playing, press 4 after the answering system plays the day and time the current message was received. To listen to the previous message, press 4 while the answering system is playing the day and time the current message was received. Stop
5 Press to stop playback and recording. Play help menu * 5 Press to listen to a list of remote commands. Skip to next message
6 Press during playback to skip the current message and advance to the next message. Record a announcement
7 Press to record a new announcement. Begin speaking after the long beep. Turn system on or off 0 Press to turn the answering system on or off. Exit
8 or hang up Press to end remote access (the call is terminated). 1. 2. 3. 4.5
0 Answering system Remote access Hang up to end the call and save all messages.
NOTES: If you do not enter a valid remote access code, the system answers the call automatically. If the date and time is not set when a message is recorded, the system announces, "Time and date not set" before the answering system announces the number of messages. If there are no messages in the answering system, the system announces, "You have no message." If there are no new messages in the answering system, when you press 2 to play back new messages, the system announces, "You have no new message." If you pause for more than four seconds during remote access, you hear a help menu listing all features and commands. If there is no command for another 20 seconds, the call ends automatically. If the memory is full, the answering system answers after 10 rings and announces, "Memory is full. Enter the remote access code." Enter your remote access code to access the messages and announcements. When the answering system is turned off, the telephone answers after 10 rings and announces, "Please enter your remote access code."
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a VTech Dect 6.0 cordless phone answering machine. I disconnected the power to the answering machine in error. I want to reset the time on the answering machine. How do I do this? My email...
Hi there,From answering your telephonemag-glass_10x10.gif when you are busy or away, to broadcasting a generic message to callers, an answering machine is a key part of your home or office phone system. When the device is working properly, it not only records and playbacks messages, but also informs you of the date and time of the call. If your answering machine is not recording messages, displaying an error code or is presenting another problem, you can reset the device and restore it to a working state.
Aug 03, 2010 | Vtech Digital Cordless Telephone VT-2568
How do I change the recorded message? we do not have a manual.
You can download the manual at
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=21714
Jul 02, 2010 | AT&T 1738 Digital Answering System with...
How do I turn off the answering machine on my Uniden cordless phone/answerring machine model # EXA 915
To turn the Answering System off, press remote on the handset. The
talk/batt low LED lights green. The current Time and Day Stamp and
number of new messages recorded is announced on the Handset receiver.
Go here to get the complete manual:
http://www.retrevo.com/support/Uniden-EXA915-Telephones-manual/id/471dj482/t/2/
-DB
Aug 14, 2009 | Uniden Lands Phones
Need to reset time ,day and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press Play/stop to exit
Setting the Clock at any time.
1 Press and hold Clock until the
Message Window displays C, and the
default day is announced.
2 To change the day setting, hold down memo/repeat
or ANNC/Skip until the
correct day is announced. Then
release the button.
3 Press and release Clock. The current
hour setting is announced.
4 To change the hour setting, hold down memo/repeat
correct hour is announced. Then
release the button.
5 Press and release Clock. The current
minutes setting is announced.
6 To change the minutes setting, hold
down memo/repeat or ANNC/skip until the
correct minutes setting is announced.
Then release the button.
7 Press and release C. The new day
and time are announced.
To check the clock, press and release
Clock.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Record a memo /
Repeat all or part of a message
I hope this helps! here is the URL to the information provided
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Feb 09, 2009 | AT&T 1717 Digital Answering Machine
AT&T Cordless Phone and Answering machine
Here is a website that has all their manuals. http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm
Aug 20, 2007 | AT&T 1480 Phone
AT&T 1480 Phone Logo
831 people viewed this question
Top AT&T Lands Phones Experts
Ekse
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
