Olympia Supertype 330 Typewriter
Problem for Olympia Supertype 330 Typewriter
Printwheel
By nubbyno1 on Mar 18, 2009
My printwheel is typing different letters and symbols that what I am typing
Comments:
Mar 18, 2009
- We have checked and printwheel is installed properly - we have turned the machine off and even tried unplugging it - but the printwheel is still printing the wrong symbols
Mar 18, 2009
- actually this happened once before and the repairman from where I bought it had me hold some buttons down and it cleared up the problem.Unfortunately I did not write down the code and the store is no longer there
Mar 18, 2009
- doesn't sound like anyone can help me
Solution #1
posted on Mar 18, 2009
Somewhat Helpful)
welcomejee
Rank: Guru  Office Equipment  Expert
Rating: 89%, 3319 votes
It sounds wheel is misaligned. Remove wheel and put it back with mark aligned.
Comments:
Mar 18, 2009
- Olymia service center would be fine to solve this problem as it seems some mechanical problem with typing wheel. Requires technician to check it personally.
Solution #2
Not Rated)
kakee
Rank: Wiz
Rating: 81%, 485 votes
Your typewriter is kinda old school. Hard to find the manual. Anyway, there's a code that you need to punch in to clear that error. You might consider calling this toll free number 1-800-816-6855 They specialize in typewriters for 25 years. Good luck!
Solution #3
Not Rated)
machadojr_fe
Rank: Guru
Rating: 85%, 289 votes
Check both the ribbon and the print wheel inside the type writer. If you remove the wheel and can feel it moving inside forward and back it needs to be replaced.
Solution #4
Not Rated)
jonb3838
Rank: Wiz
Rating: 84%, 184 votes
I could be that the print wheel has been moved around do you notice a pattern like if the you type A it comes out as a S or something like that? The alignment of the Wheel is most likely off
Solution #5
Not Rated)
emissionwiz
Rank: Guru
Rating: 90%, 8760 votes
the keys are just switch's for a small processor that then operates the correct typed symbol to strike the paper, you must have an issue the control unit that does this, it is a computer for all intents and purposes, I have a electronic typewriter and that is how it works..
Solution #6
Somewhat Helpful)
PuerkoNess
Rank: Guru
Rating: 92%, 461 votes
Try readjusting the keys to whatever the machine is typing that way you wont be confused about what you are typing anymore
Solution #7
Somewhat Helpful)
final answer
Rank: Master
Rating: 80%, 56 votes
its the printwheel adjustment problem nothing else wrong.the machine needs servicing of allparts and resetting.
Popular Solutions for Olympia Supertype 330
Questions and Unsolved Problems for Olympia Supertype 330
Do you recommend Olympia Supertype 330 Typewriter?
Answer
Answer
space bar doesn't move the carraige when typed.
Answer
the print wheel is not typing the correct letters when I push them for example if I press the d... (More)
Answer
Doesn't hold left margin it will make a noise and margin moves over, sometimes to the far left and... (More)
Answer
My Olympia Standard 210 won't print on the paper. The carriage moves and the striker hits leaving an... (More)
Answer
when typing, sometimes only partial of the letter types
Describe your Typewriters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Typewriter Experts
Top Copier & Fax Repairmen
in Burnsville, MN
(805) 813-1755
Full line Canon, Konica/Minolta, Panasonic and HP...
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
