Question about Soltek SL-K8AV2-RL Motherboard
SATA Hard Drive(s) problem with Soltek SL-K8AV2-RL Motherboard
Recently I have replaced my MB K8T800A with Soltek SL-K8AV2-RL, the processor is AMD Athlon 64 3200+, I have two DIMM(s) of memory 2x512=1Gb total of 4200 DDRAM memory, and I have two hard disks: (1)Baracuda 80Gb 7200rpm, and (2)Maxtor 80Gb 7200rpm, they are both with SATA interfaces, and they have two partitions each = 4 four partitions total. The problem occurs when I'm trying to reinstall Windows XP SP2, because the instalation program does not recognize any of the hard discs attached. Something like this appears on the blue screen: -"You have NO hard disc(s) attached to the system...". I already have an older version of Windows XP SP1 installed and it is functioning, but I face some rather silly problems with this windows. Namely, some of the old already installed programs are functioning, but some are not functioning at all ("please reinstall the program..." message appears). When I try to install a new program(s) some of them are accepted, but others are not. Please try to help me with this problem. How can I install new windows and format the discs in the process? Thanks in front.
  • Anonymous Dec 24, 2008
    I
    Namely,
    appears).
You must go to the motherboard manufacturers website (or it may possibly be on the CD that came with the board), and get the SATA drivers for windows to create a diskette (yes, a 3.5" floppy disk). When you first enter the windows setup screen at the bottom a message appears about hitting F6 to load 3rd party drivers, you have to do this. After a while a screen will show up and ask you for the drivers. Put in the floppy and hit S, then it should come up with a list of drivers allowing you to select the right one. Windows XP will ONLY look on the "A" drive for these drivers. Hope this helps
Posted on Aug 14, 2007
    Problem Solver:
  • 7 Answers
I had the same problem with this motherboard, and i am happy to say it has now been resolved.
Normally you can "make disk" for the sata controller, using the drivers from the manufacturers CD. You can even boot from the manufacturers CD's now to make a disk in a cmd prompt(with newer motherboards), or you can navigate to the /drivers/sata and copy&paste to floppy disk, which is what i have done before and what i had tried for this motherboard. However, after hitting F6 and selectecting the Sil32/silicon image sata controller, it then failed to detect the hard drive (maxtor sata). After hours of trial and error, i went to device manager and went to "properties" of the SATA/RAID controller. For this particular board its a VIA controller.
I copy and pasted the driver number and "VIA RAID CONTROLLER" and stuck it all in to google, and found a website that actually has this driver - www.driverguide.com although i am sure with a bit of digging you might be able to get the driver somewhere else. You can sign up for free at driver guide and download the driver. Extract it to your A:/ (make sure you have formatted your floppy disk first of all) and there you have it! Use this new Floppy after pressing F6, and select SATA/RAID for XP when prompted. It will then be able to find your hard drive, and enable you to carry on with your install of windows.
I hope this helps.
Colin
Posted on Feb 09, 2009
SOURCE:
I have a Soltek SL-K8AV2-R1L with one 160 gb sata harddisk (with XP on it), a 40 gb IDE harddisk on IDE channel 0, and two DVD/CD-drives on IDE channel 1. Tried to reinstall XP but XP setup did not...
Welcome to Fixya. The first thing you need to check is if the SATA Hard Disk is detected in Bios. In the system information you will see there the list of the drives including the DVD and the IDE hard drive. You can also check the Boot Sequence or Priority if it is there. Please let me know if you find the SATA hard disk on the list.
Thanks
Apr 15, 2011 | Soltek SL-K8AV2-R1L Motherboard
Hello.when to install win xp ,not instal and i have problem for sata HDD and i can`t install windos and restart my computer! how solve this problem?? sorry for bad type english language!
You have to go into your bios and make sure your cd drive is the first boot device. If you dont, your motherboard will continue to think it needs to boot from the hard drive.
Mar 20, 2011 | Soltek SL-KT600-RL Motherboard
Got a soltek sl-k8av2 rl upgrading RAM
The motherboard takes DDR 400 ram so make sure you dont put anything higher than this in.
At present i am using 2 x 512MB DIMM's, but am unsure if it will take 2 x 1024MB DIMM's. If it does, it may require a BIOS update (1.6 is the latest but 1.5 is readily available through a google search).
When you get the beep, are you still able to get into the BIOS? It might be worth checking what speed the RAM is set to. It should default to AUTO. If you need to clear your BIOS then look closely at the motherboard for JMPR1/JMP1/CLRCMOS in small white writing on the PCB.
Good luck :]
Jan 14, 2009 | Soltek SL-K8AV2-RL Motherboard
I/O error
Try changing the cables and also a diff channel on motherboard. Failing that try the hd in a diff pc to see if its faulty.
Jan 05, 2008 | Soltek SL-K8AV2-RL Motherboard
Soltek SL-75FRN2-RL
viga driver for soltek p4 vma-m
Nov 30, 2007 | Soltek SL-75FRN2-RL Motherboard
Motherboard
Processor - Supports Socket-A AMD processors (Athlon/Duron)
- Supports FSB 200/266/333MHz
Rate me SOLVED
Nov 23, 2007 | Soltek SL-75FRV Motherboard
Sata Raid
file:///E:/_DOWNLOADS/Drivers%20Computer/PDC20376_378.zip
I think this is the one.
Oct 21, 2007 | Soltek SL-75FRN2-RL Motherboard
Ide and sata hard drives
you need a converter http://www.cooldrives.com/ide-to-sata.html
Oct 05, 2007 | Soltek SL-75FRN2-RL Motherboard
Sata & ide darddrives
Hi, All dual drive capable boards read the SATA first, just make sure both SATA & IDE are enabled in the BIOS, load your O/S as normal this will load on the 1st SATA and the others will be auto detected as drives D and E, the IDDE will be E by default. Regards mistyman
Sep 22, 2007 | Soltek SL-75FRN2-RL Motherboard
Soltek SL-K8AV2-RL Motherboard Logo
973 people viewed this question
Top Soltek Computers & Internet Experts
Ekse
Paul Bade
Steven Wander
Steven Wander
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
