If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Resetting the button with Stop +Speed by 10 sec. However you must LUBE the deck belt AND rollers bearings. This happen because the lack of maintenance schedule, You must do it every 150miles aprox. See the video
This is the nature of the treadclimber, the decks are inclined until you step on them. In use they should drop with your footfalls to absorb the impact, then rise back up as your foot nears the rear of each treadle. If you would like more travel as you walk turn the dials on the shocks to a higher setting, for less travel turn to a lower setting.
1) Lube the deck belt, this is problem by lack of maintenance. 2) Test the input voltage motor, if there are voltage, the motor need repair. 3)Test the outputv voltage board, for input voltage motor, if there are NOT the board is faulty. See the diagram attached. God bless you
Can you describe your machine type (TC5000, for example) and what you've done to try and reposition the belt? Also which belt are you referring to? The treadle belt or the motor belt? I just went through a complete deck/walking belt replacement, and it's not for the faint of heart. Needed to dismantle almost 85% of the machine.
Napa 8300 silicone. Spray on each walk deck under the belts. just a quick shot from front to back in a fluid motion. test unit and see if it still shuts down.
